jeffslife
| Posted: Thu Dec 02, 2010 12:24 am Post subject: Another dumb question |
But probably not the last. While I am letting my pj warm up I notice the white is not uniform. There is an area in the bottom left side of the screen that is, for lack of the correct terminology
less than white.
virusc
Joined: 11 Apr 2007 Posts: 358 Location: Massachusetts
| Posted: Thu Dec 02, 2010 12:41 am Post subject: |
this could be many things.
convergence off
white field uniformity issues
wear(burn)
raster not centered and in far edge of lense
Picture would be helpful
jeffslife
| Posted: Thu Dec 02, 2010 2:40 am Post subject: |
very light yellowish brown
jeffslife
| Posted: Thu Dec 02, 2010 2:51 am Post subject: |
No, not really,it does become less brown though.
Elaine Benes
| Posted: Fri Dec 03, 2010 3:33 am Post subject: |
Its a burned spot on the blue tube, likely a logo of some kind
| Posted: Fri Dec 03, 2010 4:06 am Post subject: |
If it's not a vaguely recognizable shape of some kind, but more of a big blob in like a quarter of the screen, then it's probably not burn/wear, but just uniformity (lack thereof, actually).
My G70 has some slight uniformity issues on a full-white screen that I can't seem to dial out. I've never worried about it though because I only see it if I look at a perfectly all-white test pattern.
If it's not too bad, just turn off the warmup screen and you'll never see it. If it is bad, then you can dink around with the uniformity controls in the service menu and see if you can dial some of it out. Maybe you'll have better luck than I did.
jarseneau
| Posted: Fri Dec 03, 2010 3:22 pm Post subject: |
My guess is that your BLUE focus or astig is not the same in that corner vs the rest of the screen because the blue needs to be de-focused uniformly to provide uniform brightness. One way to check is to put up a focus pattern with only blue on and check the different areas with de-focus ON and OFF and see if you notice a large change in that area compared to the rest of the screen.
_________________ Jerry
roland@b4
| Posted: Fri Dec 03, 2010 5:58 pm Post subject: |
I would cover the red and green lenses and just check that it is not the very edge of the blue image. If you have lots of blue image on the other side of the warm up screen. this could be an indication that the blue is not physically centred on the screen.
AFryia
Joined: 09 Mar 2006 Posts: 965 Location: S.E. Michigan VPH-G70Q
| Posted: Fri Dec 03, 2010 9:50 pm Post subject: Re: Another dumb question |
| jeffslife wrote: | But probably not the last. While I am letting my pj warm up I notice the white is not uniform. There is an area in the bottom left side of the screen that is, for lack of the correct terminology
less than white. |
How does the picture/video look?
That's all that matters.
Desktops and test patterns will lead you astray!
jeffslife
| Posted: Sat Dec 04, 2010 2:50 am Post subject: |
picture looks good ( to me)
its only 1080i
not 1080p like SC but very watchable
