TheVerge
| Posted: Tue Nov 09, 2010 2:57 pm Post subject: How long can the raster be off the tube face |
How long can the raster be off the tube face before it overheats and implodes. When i first turn on my NEC PG, all three tubes light up with a wicked, spider web looking raster and one corner goes off the tube face on all 3 tubes. I wonder how long i can leave it like this before it does damage as it takes time to shift it back normally.
| Posted: Tue Nov 09, 2010 3:07 pm Post subject: |
If it's blank raster, then for a long time. An all white 100IRE image, not long at all.
| Posted: Tue Nov 09, 2010 8:18 pm Post subject: |
Can't comment on NEC's but i've seen Marquee 8 inchers with the raster actually burned and wrapping around the face of the tube.
TheVerge
| Posted: Tue Nov 09, 2010 9:12 pm Post subject: |
I'll try and center it tonight i guess, if it implodes, to the trash she goes !!!
| Posted: Wed Nov 10, 2010 3:08 am Post subject: |
If its trash to you, its tresure to me. Dont throw it out!!
CZ Eddie
| Posted: Wed Nov 10, 2010 4:26 am Post subject: |
| draganm wrote: | | Can't comment on NEC's but i've seen Marquee 8 inchers with the raster actually burned and wrapping around the face of the tube. |
What, really? So the tube wear was so large that you could see it run right off the sides of the tube face?
_________________ Back after a digital sabatical.
| Posted: Wed Nov 10, 2010 11:12 pm Post subject: |
| CZ Eddie wrote: | | What, really? So the tube wear was so large that you could see it run right off the sides of the tube face? | no not so large but totally off center like whoever set it up had no clue. I should have saved that tube for show-n-tell but it was many, many years ago.
virusc
Joined: 11 Apr 2007 Posts: 358 Location: Massachusetts
| Posted: Thu Nov 11, 2010 2:38 pm Post subject: |
Maybe Curt can confirm this but I think the type of tube itself makes the biggest difference. Some of the older 07ms and small tubes like that seem to be hard to crack even with full white at high contrast over tube face for long periods of time.
