Problems with ViewSonic p227FB...
Trans-Am
Posted: Fri Oct 29, 2010 5:50 pm    Post subject: Problems with ViewSonic p227FB...
Hi everybody !
I bought this used monitor for 40€ a few monthes ago :
(don't care about the flash which made the screen all gray/green)
It's a 2006 ViewSonic P227FB Professional Series, one of the last 21" CRT monitors. Very Happy
It uses a Samsung tube (Shadow Mask), so it's not as good as my CPD-G520 but it can display the 1080p@50Hz resolution of my PS3 via a HDfury1 with a perfect centring. (unlike the Sony)
When I switched on this thing for the first time (3-4 monthes ago), the picture was a bit blurry, so I adjusted the focus controls on the flyback and the picture was more sharp.
Since a few weeks, I'm under the impression that it is not as sharp as it was when I adjusted it a few monthes ago, as if it has become blurry very progressively.
I could unterstand it for a period of 10 years, but I adjusted the focus of this monitor 3 or 4 monthes ago.. Neutral
The other problem I have is the brightness level which fluctuates from time to time.. Sometime it starts very bright and stays like this (unlike Sony monitors) until I switch off it. It was so many bright one time that I must reduce G2 voltage (with the control on the flyback) to have a good level of black, but later, when it comes back to a "normal" level of brightness, the screen was too dark even with OSD brightness adjustement @ 100% .. Sad
Maybe the G2 voltage which is not steady ?..
When I adjusted focus and G2, I cracked the glue which was on the controls and didn't replace it with anything, but the pots are not easily movable (unless with the screwdriver of course), I don't think those things could turn themselves, but who knows.. Surprised
Otherwise it's a good monitor, so if somebody have an idea about the source of those problems (the flyback, or just a faulty resistor..), please let me know ! Cool
Thanks in advance an sorry for my english ! ><
speedracer
Posted: Sun Nov 07, 2010 11:06 am    Post subject:
the fluctuating focus is a bad sign
speedracer
and your english is fine
Trans-Am
Posted: Sun Nov 07, 2010 9:17 pm    Post subject:
OK, thanks ! Smile
It's a pity that these monitors are not built to last.. Confused
Neverthleless, the focus keeps relatively correct, so I'll keep using it to display my PS3 untill it's dead. Embarassed
Posted: Sun Nov 07, 2010 9:24 pm    Post subject:
Trans-Am wrote:
OK, thanks ! Smile
Wait for Macguyver to come in here. He'll tell you what to fix.
