Will GT17 lenses help my NEC 10PG?
rtart
Posted: Thu Oct 28, 2010 6:52 pm    Post subject: Will GT17 lenses help my NEC 10PG?
Hi all, I have the HD10's on my 10pg and have a chance at a set of GT17's. Will the GT17's give me better edge focus?
I'm at 154" from the screen wall with a 120" 16:9 screen.
Do I want them, or am I better off with my HD10's?
Posted: Thu Oct 28, 2010 7:15 pm    Post subject:
YES!! get them the HD 10's are not even close on corner focus.
dvh99
Posted: Thu Oct 28, 2010 7:37 pm    Post subject:
double yes, only the hfq900s are better.
they are good for a screensize up to 3mtrs wide i think, check the sticky lenses thread here on the forum its full of info.
rtart
Posted: Thu Oct 28, 2010 10:01 pm    Post subject:
I've got a 96" wide 16:9 screen. What's a fair price?
Posted: Fri Oct 29, 2010 1:06 am    Post subject:
Paul has a set for sale here. They are labled Barco HD-120 but are the same as the HD10GT17.
they are really nice lenses and for 200 bucks grab them!!!
https://www.curtpalme.com/forum_archived/viewtopic.php@t=24020.html
dvh99
Posted: Sat Oct 30, 2010 3:00 pm    Post subject:
ah you bought them, you wont regret it.
rtart
Posted: Sat Oct 30, 2010 6:21 pm    Post subject:
I did. Super quick shipping. I'll post when I install them.
Thanks to all for the guidance.
rtart
Posted: Mon Nov 15, 2010 8:55 pm    Post subject:
Well, I installed them. The resolution is truly better than my HD10's because I could see scan lines where there were none before. I ran my system for years at 1080i because there was no difference in PQ between 1080i and 1080p as far as I could tell. Why stress the PJ if there was no improvement? Well, with the GT17's, there was obviously more PQ to be gained.
I have run video via component through a DVDO VP30 to my 10PG for a long time. I bought a HDFury1 a couple years ago and never got through the setup...for several reasons. However, since it was obvious that the lenses could do more, I decided to dive into the HDF setup once more. Many have told me that the HDMI output of the PS3 was far superior to component (Kal being one) so I jumped back in. After an interesting Saturday, I was able to integrate the HDF into my system and the PQ improvement was pretty substantial. I created a 1080P profile in the PJ and set it up from scratch. I used the VP30 to provide the signal initially, then I added the HDF which then locked on the profile. I'm using the VP30 to control gamma, and not using pass through, which was a problem in the past. I'm using the VP30 to manage the image shift issue so the PJ is not called upon to do it.
I'm seeing detail I did not know existed before, and for only $160 out of pocket. (I have the old lenses sold if I can just find a box to ship them in...)
Posted: Mon Nov 15, 2010 11:02 pm    Post subject:
Told ya you'd like them Wink
Posted: Tue Nov 16, 2010 4:37 am    Post subject:
Impressive.
