3D from Barco 708s?
nemmi69
Posted: Mon Oct 25, 2010 8:03 pm    Post subject: 3D from Barco 708s?
Any one know the best way to get 3D from Barco 708s?
What doesn't kill you is only biding it's time
Posted: Mon Oct 25, 2010 8:13 pm    Post subject: Re: 3D from Barco 708s?
With that kind of bandwidth and brightness it's going to take a small screen and low resolution to look good at all. If you're looking to mess around with gaming, it could be OK if you run some crazy resolution and are OK with flicker... but I'm not sure. For movies it's almost certainly not going to be worth the tradeoffs.
Elaine Benes
Posted: Tue Oct 26, 2010 1:56 pm    Post subject:
The little Barco's don't have the resolution, bandwidth or anything else needed for 3D, not without compromises much more serious than the slightly elevated black level of a 3D digital projector.
dokworm
Posted: Wed Oct 27, 2010 1:16 am    Post subject:
I'd grab a $350 120Hz DLP 3D capable projector to play with, on the 708s, the flicker would drive you nuts for 3D.
