A lens question
_in_peace_
Posted: Mon Oct 18, 2010 11:17 am    Post subject: A lens question
Hello!
Is there a difference between lens for Red and Green?
(In aspect of the angle) 8" HD134
Thanks!
jeffslife
Posted: Mon Oct 18, 2010 2:34 pm    Post subject:
I swapped them out on my old zenith 900 pro X, using a spare parts machine. It made no difference.But I cant say about other pj's.
We are ALL job creators !
_in_peace_
Posted: Mon Oct 18, 2010 4:05 pm    Post subject:
Ok i did a phosphor grain focus test (Thank's Guy Kuo / Brian Smile ) on my new curved screen and the sharpness-angle seems different between the two... And the "sharpness-curve" would fit better if i swap them.
I think i do a swap after all and try it out. The case is that one lens is marked blue and the two others don't have any.
Posted: Tue Oct 19, 2010 6:12 am    Post subject:
The lenses should all be the same unless they have built in Red and Green filters.
_in_peace_
Posted: Tue Oct 19, 2010 9:36 am    Post subject:
After the test i noticed there was no difference also Smile
By the way, the Grain Focus trick is fantastic!
deronmoped
Posted: Wed Oct 20, 2010 4:18 am    Post subject:
The only difference you will notice in the lenses is, they are not all made the same. In other words they are not sold in matched sets. Where this can be a problem is in convergence. If you are having a issue with convergence, try swapping lenses around to see if that helps the problem. Especially if your running the image out to the edge of the tube.
Deron.
