Help please
CRTChris
Posted: Thu Oct 07, 2010 3:31 pm    Post subject: Help please
Ok I do not know why I am having such an issue with all of this. however this is my issue. I have a NEC PG6 Xtra And want to connect Component cables to it however it has RGBHV So I have the cable that takes you from RGBHV to VGA now I would like a way to get it from VGA to Component. Everything I own has Component and not HDMI I do not have any way to upgrade everything to Hdmi so this is jus the way it has to be. So any help would be great as well.
Thank you in advance.
Posted: Thu Oct 07, 2010 4:31 pm    Post subject:
You need a transcoder:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=6860.html
or
https://www.curtpalme.com/forum_archived/viewtopic.php@t=10987.html
Posted: Thu Oct 07, 2010 6:23 pm    Post subject:
Also, read this:
http://www.curtpalme.com/CRTPrimer_17.shtm
A component signal is not equivalent to an RGBHV signal, and as Analog says, you need an electronic piece between the two signals to convert one to another. A simple cable won't do the conversion for you.
CRTChris
Posted: Fri Oct 08, 2010 7:29 pm    Post subject:
Thank you all for the help. I was looking for some thing lower cost however this seems to be the only way.
Thank you again for the help
CRT_Ben
Posted: Fri Oct 08, 2010 8:20 pm    Post subject:
Nice screenname! Wink
You can probably buy a used transcoder for cheap money if you look around.
CRTChris
Posted: Sat Oct 09, 2010 12:57 pm    Post subject:
I checked the Buy/Sell forum maybe I will post a wanted add.
Thanks and nice screen name as well Smile
