| Posted: Fri Sep 17, 2010 2:25 am Post subject: |
Sorry, I had the wrong pages, Curt's manual is a little different than mine.
| Posted: Fri Sep 17, 2010 2:31 am Post subject: |
OK, I set the clamp to H/C; we'll see what that does.
I'll check the manual.
| perisoft wrote: |
...That still doesn't explain the slight jitteriness, or, more worryingly, the random times when green drops by 80% or so.
After you look at pages 48-49, go into the menu and set everything to HC that can be and HV that can be.
| Posted: Fri Sep 17, 2010 2:35 am Post subject: |
| CIR Engineering wrote: | | perisoft wrote: |
craigr |
Done - though there wasn't anything I could set to HV. Just clamp to HC.
I'll try setting some random modes and see what I get.
| Posted: Fri Sep 17, 2010 2:39 am Post subject: |
After you look at pages 48-49, go into the menu and set everything to HC that can be and HV that can be. |
After you do that, if you're still having trouble, try disconnecting your source altogether, throw up the E or color bar test pattern, turn the contrast down a little, and leave it run for awhile and see what it does.
| Posted: Fri Sep 17, 2010 2:51 am Post subject: |
| ecrabb wrote: | | CIR Engineering wrote: | | perisoft wrote: |
SC |
Good idea. I'm about to pack it in for the night, but it's in my office so I can have it test-pattern-ing at 20 contrast for a while.
It grabbed everything I threw at it except for 1080i25... unfortunately I haven't been able to get powerstrip working on my hacker machine, so I can't do any real testing with different freqs, porches, etc.
At this point the green dropout is what worries me the most; the next thing is the super-high-frequency heat haze / mosquito noise thing.
The green dropout happens in the menus too, but as above haven't tested with no source. The heat haze / noise depends on the source; when using the red-output Moome card, it was solid as a rock. And I'm not talking some pebble sh*t, either.
Yeah. That solid.
That said, the Barco's always had a bit of the same thing - though not as bad. Could probably be due to any number of cable/grounding/etc etc etc things.
More tomorrow as I get a chance...
| Posted: Fri Sep 17, 2010 1:39 pm Post subject: |
Yeah, I think the haze is from a crappy noisy source, especially since you don't see it with a digital connection
If the clamp is wrong, the colors can drop out, so the internal test patterns with no source connected is a really good idea in many ways.
Also, I would keep the hatch open while you work on it. When green drops out, check to see if the heater stays on or not. You may also want to fiddle with the BNC connections on the B board and neck cards. While you are at it, you could tell this poor guy which colors go where on his B board
http://www.curtpalme.com/forum/viewtopic.php?p=269022
If green keeps dropping out you could start by swapping neck cards between the blue and green tubes. You could try swapping the red, but I think it is 180 degrees opposite the other two due to the tube orientations.
| Description: |
| Filesize: |
32 KB |
| Viewed: |
4976 Time(s) |
| Description: |
| Filesize: |
12.74 KB |
| Viewed: |
4975 Time(s) |
| Description: |
| Filesize: |
10.15 KB |
| Viewed: |
4975 Time(s) |
| Description: |
| Filesize: |
8.69 KB |
| Viewed: |
4975 Time(s) |
| Posted: Fri Sep 17, 2010 2:16 pm Post subject: |
| CIR Engineering wrote: | Yeah, I think the haze is from a crappy noisy source, especially since you don't see it with a digital connection
If the clamp is wrong, the colors can drop out, so the internal test patterns with no source connected is a really good idea in many ways. |
Yep, I'm about to try it.
The thing that worries me is that the colors drop out *on the menus* too, or in the test patterns. Still with a source connected, but the drop-out affects everything.
[/quote]
[/quote]
Heater? Guess I'll have to open the hatch and look around in there.
The dropouts don't last that long; a few seconds to a minute, so it might be hard to check that.
| Quote: |
I thought about it, but I know nothing about this PJ yet, and I don't want to be responsible for him blowing his sky high!
| Quote: |
So noted. Thanks!
| Posted: Fri Sep 17, 2010 8:18 pm Post subject: |
OK, so, I had it run for a while and got it to do "the thing". It took a while, and it did "the thing" for maybe 4 or 5 minutes. I got some pictures.
It was exciting.
Any ideas? It just kinda snaps back to normal like nothing ever happened. I've tried to have it sit there on a test pattern with no input, but it seems to drop back to a screensaver mode, so short of sitting there for an hour poking it every five minutes, I'm not sure how to check more.
| Posted: Fri Sep 17, 2010 8:42 pm Post subject: |
OK, update: I had it sitting there with no input and color bars and for some reason it stayed there... it did the same thing. Dropped green mostly for a few minutes and then came back on its own.
So, seems like it's gotta be an internal problem. Ideas?
| Posted: Fri Sep 17, 2010 9:06 pm Post subject: |
Hmm... So, just green is cutting output by 50% or so... I'll have to let Curt or Craig chime in on this one.
You just moved the machine... Have you double-checked and/or reseated all the cards?
| Posted: Fri Sep 17, 2010 10:15 pm Post subject: |
Well, my first guesses would be a neck card, bad connection to the neck card (check all wires and reset neck card on tube), tube, or BNC connector between the C and B board.
| Posted: Sat Sep 18, 2010 1:25 am Post subject: |
| CIR Engineering wrote: | | tube |
Oh, don't even go there! If there's a dude tube in this thing it isn't worth the paper it's printed on; I'd be lucky to get my money back out of it...
I reseated the green neckboard, which didn't appear to be on all the way and whose clamp collar was, like, totally un-tight. Fired it up, and... the first thing it did after running for 3 minutes was blip the green down for a second or two. I'm gonna run it a bit and see how things go...
How long do I need to wait after shutdown for the tubes to discharge so I can swap neckboards? I'd prefer not to fry it, me, or both of us.
| Posted: Sat Sep 18, 2010 5:19 pm Post subject: |
| perisoft wrote: | | CIR Engineering wrote: | | tube |
How long do I need to wait after shutdown for the tubes to discharge so I can swap neckboards? I'd prefer not to fry it, me, or both of us. |
So when the green blips off, have you checked to see if the filaments go dead or not yet? If it's the filaments it is probably the neck card or tube. If the filaments stay lit, it's probably a neck card, bnc, or B board.
I don't know how long you should wait... I usually just be careful and just go right in. You could wait if you want to be safe, but I don't know how long. It's only 200 volts back there so it's not all that bad
| Posted: Sat Sep 18, 2010 10:48 pm Post subject: |
Disconnect the HV lead from the splitter and touch it to the head of your wang. If you see no change in length or girth you're probably good to go
That's how Curt does it (from what I've heard)
_________________ Chip
| Posted: Sun Sep 19, 2010 2:58 am Post subject: |
| stefuel wrote: | Disconnect the HV lead from the splitter and touch it to the head of your wang. If you see no change in length or girth you're probably good to go
That's how Curt does it (from what I've heard)  |
Hey, that's my technique...
https://www.curtpalme.com/forum_archived/viewtopic.php@t=20432.html
| Posted: Sun Sep 19, 2010 4:13 am Post subject: |
Craig, is there an ISF standard for nutshock discharging? I'd love to be in the classroom for that one.
Anyway - I pulled/reseated the b-board, and checked the wiring over to the G neckboard, and reseated that again too. There was nothing obviously off.
Fired it up, and spent a while screwing with scheimpflug, focus, etc (got optical focus better in 20 minutes than it's ever been on the Barco...). The PJ was probably on for 3 hours total, though I wasn't looking at it the entire time. I didn't see it flicker.
So, we'll just have to see how long that holds. With an intermittent problem, it sucks, because maybe it acts fine for two weeks, I hang it up, and wham, out goes the green... Guess I just gotta play it by ear.
| Posted: Sun Sep 19, 2010 1:40 pm Post subject: |
| perisoft wrote: | Craig, is there an ISF standard for nutshock discharging? I'd love to be in the classroom for that one.
So, we'll just have to see how long that holds. With an intermittent problem, it sucks, because maybe it acts fine for two weeks, I hang it up, and wham, out goes the green... Guess I just gotta play it by ear. |
Well, I think with the green only cutting out part way and not going full off, and with intermittent, that it is (hopefully was) most likely a loose connection. Often even if boards and plugs are seated all the way they still may not be making a good connection. Corrosion, time, and moving the projector can have an effect after ten plus years.
I would also disconnect and reconnect all the other plugs going to the green VNB. Also, you should probably reseat the HV cable for the green tube just to be sure that it is in all the way.
In the order of likeliness for the problem my opionion is:
1) loose connection
2) bad neck card
3) ABG circuit (I forget which board on G70)
4) tube
5) B board
6) Y boards
7) Other
| Posted: Sun Sep 19, 2010 4:20 pm Post subject: |
OK, I gotta say I'm kinda pleased with myself for this one.
I can't be sitting here looking at the PJ all the time, right? And I don't want to be running very high contrast either. But I need to know if the thing is dropping out. What to do?
Well, I had that webcam, right? My initial idea was to code something myself, but I found that unnecessary. I grabbed a nice app called Yawcam, which lets you see the webcam in a more direct way and without Logitech's awful software. I set it up to not have auto gain control, turned the contrast down to about 24, and pointed it into the lens. Now, even with the contrast down and the sensitivity down, the camera just sees white. But I have it looking at the edge, so the tube light blooms outward.
I have Yawcam set to motion detect, like for intrusion detection - and I set the detection area to be the area NEAR the tube face. If the contrast drops suddenly, the bloom goes away, and WHAM, it records the time and takes a screenshot.
So, I can leave it running like this for quite a while, on super low contrast, and if the green drops out it'll record when and for how long. I tried it, and if I quick drop the contrast down by even about 10% with the remote, it'll grab it.
If I had more time I'd have a VB app recording the luminance to a graph, but I don't. But this should work fine since the events are always sharp.
Yeah, go me.
(Oh, and by the way, Yawcam will grab any webcam installed, and let you use its settings. And since you can stretch it around on-screen and actually enlarge the image (!) and it uses software, Focus!Focus! (my MTF detector) works perfectly. So there's another problem solved.)
| Posted: Sun Sep 19, 2010 5:04 pm Post subject: Re: Hey, it's a G70 XXXXX troubleshooting thread! |
| perisoft wrote: |
... this is a freaking Jeep-to-Land Rover kinda move here. Yikes! |
Yes it sure is.
Barco = Jeep = reliable
Sony = Land Rover = breaks down a shiteload. ***
**** yeah, but, but..... when it DOES run, its a nice ride.
