wildchild22
| Posted: Wed Sep 01, 2010 3:37 pm Post subject: nec xg 1352 lc frame rate help |
I have a nec xg 1352 lc and am about to get it going. I have confirmed it is working properly.
I have the nec xg 1352, moome newest internal hdmi card, and an old lumagen dvi not hdp or hdq.The lumagen can do interlaced resolutions such as 1080i @ 100hz and below it seems using my digital projector for a test.
So the question is for bell hdtv here in Canada they send out all HDTV as 1280X720p @ 60hz should I use the lumagen and up the frame rate? 30X3/1.001=89.91 hz?
And for bluray 1080i @ 95.90hz
24x4/1.001
what is the views on framerate.
Maybe I should run only 1920X1080i @ 119.88 hz that way it should work for ntsc video 29.97 and bluray video 23.976 hz.
Right now the previous owner has it all set up for celing mount and I am looking into the tube face trying to read the lumagen output the image looks fine at 1080i @ 119.88HZ BUT IT IS NOT 1920 it is a lower number.
1893@1080i @71.92 hz (previous owner setup looks perfect)
1599@1080i @119.88hz (just changed frame rate and left everything else alone|) but the image on one side is wrinkled probably needs the timing fixed.
If I change the 1599 to 1920 then the image moves over to the right side of the screen alot so I unplugged the lumagen so I wouldn't hurt anything. Maybe it can do the full 1920X1080i @ 119.88 but needs the settings changed or maybe the lumagen dvi can handle the full 1920 so it drops it back to 1599.
wildchild22
| Posted: Thu Sep 02, 2010 7:54 pm Post subject: |
any ideas?
Artinaz
| Posted: Fri Sep 03, 2010 7:48 pm Post subject: |
Its difficult to diagnose the prior owners settings. What memory setting are u using ? if you are not using memc or memd, I would suggest setting up those memories on the lumagen and starting from scratch. That way u still have mema and memb with the prior owners settings.
I am surprised u are getting 120 hz, I have a lumagen dvi too, and I cant get 120hz on 1080i. The input only allows 2 digits.
Azi
wildchild22
| Posted: Fri Sep 03, 2010 8:08 pm Post subject: |
1080p 23.976 input and output as 1080i@119.88
