bfeils
| Posted: Sun Aug 29, 2010 2:16 am Post subject: nec pg HELP |
So, I put a pg6200 in my parents place which has worked great for the last three years but recently started to not work properly intermittently. All I get when I start up the projector is a garbled mess across the screen similar to when my marquee projector isn't syncing. This is happening with or without a source being present. Where is the first place to start looking? All my prior experience is with marquee's.
jarseneau
| Posted: Sun Aug 29, 2010 1:24 pm Post subject: |
Not sure I'm clear on the problem..
-Do you get normal menus when no signal is input?
-Are you sure you have the RGBH&V connectors on their proper inputs? It's easy to get off by 1 as there's an extra terminal there for ACAT
_________________ Jerry
bfeils
| Posted: Sun Aug 29, 2010 2:57 pm Post subject: |
Even the menus are unreadable and that's what has me confused. IF the projector doesn't have any cables plugged in it should go to a internal timing for the the menus and everything right?
| Posted: Sun Aug 29, 2010 3:00 pm Post subject: |
Bad system or deflection board usually. I've got spares if you need them, or can repair yours.
bfeils
| Posted: Sun Aug 29, 2010 4:22 pm Post subject: |
OK. I'll go to there house and pull those boards. Curt, will you pm where to send the boards.
Thanks - brandon
jarseneau
| Posted: Mon Aug 30, 2010 2:33 am Post subject: |
Probably is the board problem but make sure it's not just the 'red button'.
bfeils
| Posted: Mon Aug 30, 2010 3:09 am Post subject: |
Well guys, I went to the parents house and removed the suspect boards. Everything looked fine, no sign of burns on the boards or leaking caps so I cleaned all the connections and whalaaaa. I'm in business again. Hopefully it lasts.
Thanks for the insight guys.
- Brandon
Jeremy112
| Posted: Mon Aug 30, 2010 3:34 am Post subject: |
| jarseneau wrote: | Probably is the board problem but make sure it's not just the 'red button'.  |
It took days to find that darn thing too! :p
