Mac, Toshiba 61H70 Hyper board Question.
Posted: Mon Aug 23, 2010 12:20 am    Post subject: Mac, Toshiba 61H70 Hyper board Question.
Hi Mac, My Refrigeration guy had his Toshiba looked at by a tech and they said its his Hyper board.
I looked up on the net and found one thread where they said to replace all electrolytic caps.
From the looks of them they all look fine, I'll still change them but is there anything else I should look for on the board?
He had the wavy line symptom.
Posted: Mon Aug 23, 2010 12:33 am    Post subject: Re: Mac, Toshiba 61H70 Hyper board Question.
Ut oh. You posted in the wrong section. Your in trouble now. Laughing
Yes, recapping is the correct procedure but also carefully look for damaged traces from these caps. It is very common to find damaged traces. Post your outcome. Very Happy
But like I told Chip, I'm only guessing at this stuff, lol. Laughing
Posted: Mon Aug 23, 2010 12:36 am    Post subject:
LMAO!!! I missed you the past few week mac. And keep up the argumentative theoretical nature you have, its one of your best qualities and educates us and yourself. Wink
Posted: Mon Jan 03, 2011 10:31 pm    Post subject:
Well re-caping did not fix it, I forgot to check the traces though. Sad
Posted: Thu Jan 27, 2011 2:33 am    Post subject:
Well Mac he put it in and was still doing the same thing. So i had him remove the entire chassis. I have it here and took off the mother baord that the Hyper board is soldered to. Looks like he or the other person who first removed it messsed up the ground
solder points on the mother board.
here is one side
The solder mask is tore off, I did not even want to start to remove what is done. On the other side it looks like they used a pice of copper wire to connect the cage pins due to possibly having the ground plane all messed up?
blurry pic sorry.
But before i can check the traces on the Hyper board I wonder if its even worth looking at after seeing this.
the one SMD resistor in the pic that looks like it was too close to his soldering reads fine.
Posted: Thu Jan 27, 2011 11:15 pm    Post subject:
Not sure what to tell you there. You've got your work cut out for you.
Posted: Thu Jan 27, 2011 11:30 pm    Post subject:
Oh flashbacks.
Mac,
that looks like what I walked into with that torched sub amp that never made it to you.
It's still in the box with your old address on it Laughing
In my case, someone before me tried to fix it with a chainsaw and blowtorch Rolling Eyes I got it to fire up but there's still something missing connection wise.
Posted: Thu Jan 27, 2011 11:46 pm    Post subject:
Yeah, sucks. I dont think its going to be worth my time removing the hyper board from that mess. I cant even tell if any other traces run near there that might have been damaged.
Well this week i have to replace my Turbo in my EVO, so this will have to wait.
Posted: Fri Jan 28, 2011 12:00 am    Post subject:
stefuel wrote:
Oh flashbacks.
Mac,
I use to sit by the mailbox everyday waiting for that amp........... yeah right, lol. Laughing
Posted: Fri Jan 28, 2011 12:02 am    Post subject:
Just think of how many good boards for that tv are rotting away at the dump..... Laughing
