Panasonic TC-P42X24 Plasma
Bob_Collins
Posted: Thu Aug 19, 2010 4:23 pm    Post subject: Panasonic TC-P42X24 Plasma
The set is an entry level set, but it should be able to be calibrated to look better than out of the box.
Attached is the report from ChromaPure using a Chroma 5 meter. The tracking and grayscale look good to me, but the gamma sure looks screwed up (and low), and the contrast ratio is lower after calibration than before. Any tips or suggestions on what to do to improve things would be greatly appreciated.
FYI, it only has COLOR & TINT for color adjustments.
My user settings are:
Picture Mode: Cinema
Contrast: 62
Brightness: 61
Color: 46
Tint: +19
Sharpness: 50
Color Temp: Warm
XV Color: Off
Video NR: Off
MPEG NR: Off
Black Level: Light
3:2 Pulldown: Auto
CalibrationSummaryDetailed.pdf
ChromaPure report
 Filename:  CalibrationSummaryDetailed.pdf
 Filesize:  131.23 KB
 Downloaded:  4 Time(s)
Tyler Pruitt
Posted: Wed Aug 25, 2010 10:31 am    Post subject:
You adjusted the grayscale via the cuts and drives in the service menu correct?
Bob_Collins
Posted: Thu Aug 26, 2010 12:02 am    Post subject:
Yes. I know of no other way to do it.
