NEC XG1100 - Rate these tubes! :D
Jeremy112
Posted: Tue Aug 10, 2010 7:23 pm    Post subject: NEC XG1100 - Rate these tubes! :D
Hey guys, was cleaning up the lenses and tube faces and did the scheimpflug at the same time, I decided to get a pic of the tubes.
What would you rate them at?
I'd say 8 -7/6 -7.5/8 in R-G-B order from left to right
Posted: Tue Aug 10, 2010 8:00 pm    Post subject:
Left to right 8-5-7
donaldk
Posted: Tue Aug 10, 2010 8:21 pm    Post subject:
756
Left and right show my generally low scoring on tube wear;-).
Mr. Green
Posted: Tue Aug 10, 2010 8:38 pm    Post subject:
8, 6, 8
How many hours on em?
Jeremy112
Posted: Tue Aug 10, 2010 8:56 pm    Post subject:
The counter is most likely wrong, since it says about 300-400 for the 3 tubes (how nice it would be if they were really only 300-400 hours of wear).
Elaine Benes
Posted: Tue Aug 10, 2010 9:23 pm    Post subject:
7-4-7
You've got a static image burn as well as wear on that green, it will drive you crazy if you know its there...
However, even crappy tubes like that can look great in an NEC, you can likely even get it to do D6500 and you won't even notice the wear as long as you stay within the worn area.
Posted: Tue Aug 10, 2010 10:33 pm    Post subject:
Also, I'll take a stab in the dark here and say that the blue has probably been changed. No way should the red and blue be so close in wear. The blue should be closer to the green than the red.
Jeremy112
Posted: Wed Aug 11, 2010 1:01 am    Post subject:
I was thinking the same thing steful, because so far this is the only projector that I have seen equal wear on the red and blue tube. Actually its the only CRT I have had that has wear on the red tube. Still not bad though, if I could find a nice 8+ green It'd be nice!
Still throws out a hell of an image, havent had any complaints yet Thumbs Up
Jeremy112
Posted: Wed Aug 11, 2010 1:52 am    Post subject:
and I will admit, the previous setup of the projector looks very nice on the tubes (a lot better than some I have seen on the tube rating chart thats for sure Very Happy) I assume to get that perfectly square wear that it has someone had the projector lenses at a perfect or near perfect 90 degree angle to the screen?
Im tempted to rip out the wall where my 55 gallon aquarium is and make the room a bit bigger so I can move the PJ back for a larger image since Im probably a bit too close to my screen with where it currently is (The XG is a wee bit longer than my PG was Wink)
RayN999
TV/Projector: Sony VPL-VW60 and Toshiba 65H84 CRT RPTV
Posted: Wed Aug 11, 2010 2:03 am    Post subject:
Tear down the wall.....
Ray Nelson
N9QBV
Ben851
Posted: Wed Aug 11, 2010 12:46 pm    Post subject:
My XG's Red was actually WORSE than the blue - and I'm pretty sure they were original tubes... maybe a trait of the projector?
Talk to me in a year or two after a few thousand hours on my new tubes and we'll see what the wear looks like.
Ben
MikeEby
Posted: Wed Aug 11, 2010 3:20 pm    Post subject:
My understanding is a NEC can eat a Green tube very quickly. Mine has a little over 2K on the clock all put on by me over the last 7 years and has very noticeable wear. Contrast has never been higher than 73 and brightness never higher than 71.
Posted: Wed Aug 11, 2010 3:29 pm    Post subject:
A red tube can be a 6-7, and you still won't see the wear between worn and virgin phosphor. No explanation for it, but that's the way it is..Smile
