Ampro Codes
donr
Posted: Sat Aug 07, 2010 7:40 pm    Post subject: Ampro Codes
Hi all
I want to redo a complete setup of my pro 4000G from scratch. What are the codes so I can zero or remove all the garbage that is in the pj? My manual states code 29 to clear active channel and code 79 to reset internal screens. Which one do I use or if there is another code that does this? Thank's
Don
incova
Posted: Sun Aug 08, 2010 1:41 am    Post subject: hi
code 29 resets the active channel, thats the channel you are using to watch your dvds etc, it will undo your convergence etc.
code 79 will reset however you have set up the internal help screens to default as well, these are the screens you use when you press the help button.
The more I learn
the less I know.
Posted: Sun Aug 08, 2010 3:47 am    Post subject:
Just for Chip...
Write this number down for AmPro repairs. 911 Smile
Posted: Sun Aug 08, 2010 10:44 am    Post subject:
Tom.W wrote:
Just for Chip...
Hmmm, I think I have that but never needed it. Funny, that code is the same for Barco's, Sony's AND Marquee's and get's used on a regular basis.
I do think there is a reset code. It's like a 4-5 digit factory service code. You don't need it. Just clear the active channel.
Tom. Is your middle name Pete Laughing
donr
Posted: Sun Aug 08, 2010 2:50 pm    Post subject:
Thanks. I guess once that is done, I use it as default to copy to other channels?
incova
Posted: Sun Aug 08, 2010 4:12 pm    Post subject: yup
You can but I tend to set them up as I go along, you may have to do some adjustments as you go from one resolution to another in each channel if you are going to copy it to all channels once you are done.
The more I learn
the less I know.
