eliminating noise in picture with vga out from pc.
dvh99
Posted: Tue Aug 03, 2010 12:57 am    Post subject: eliminating noise in picture with vga out from pc.
if this is in the wrong thread feel free to move it.
http://www.extron.com/product/product.aspx?id=ada2-gli350xi&subtype=287&s=4#feature26175
anyone has any experience with this device?
i still have a lot of noise in the picture when using vga out.
from my ps3 to the moome the picture is much cleaner with almost no noise.
Posted: Tue Aug 03, 2010 1:18 am    Post subject:
What kind of noise are you getting?
dvh99
Posted: Tue Aug 03, 2010 1:46 am    Post subject:
faint horizontal lines going vertically up and down in the background.
jarseneau
Posted: Tue Aug 03, 2010 2:47 am    Post subject:
I have the Extron ADA 2 300 model (must be an earlier version rated at 300Mhz) and it does a great job to deliver a clean VGA signal. I used to have a slight signal reduction caused by looping the VGA through an HDTV tuner card and the output from the Extron cleaned and provided a stronger signal (restored contrast & eliminated noise). Can't say I ever drove the lengths you are using but it is a very capable device.
Jerry
dvh99
Posted: Tue Aug 03, 2010 1:13 pm    Post subject:
this thingy goes on my wishlist along with new tubes modded 03p vim barco focus coils hfq900 lenses and a radiance xs+.
835 euro asking price for this extron box.
Posted: Tue Aug 03, 2010 1:24 pm    Post subject:
You have a ground loop.
Plug the PC and the CRT into the same outlet, and unplug the sound (for testing). Just use the one outlet.
VGA from a PC should be fine. I'm running mine through a NEC switcher (to split the signal), but direct works fine too.
dvh99
Posted: Tue Aug 03, 2010 1:28 pm    Post subject:
outlet, you mean the 220volt in the wall mark?
i will try that thanks.
jantje112
Posted: Tue Aug 03, 2010 1:39 pm    Post subject:
If you wan't a good line driver, just use a crystalio II. Much better then the extron device and the best you can get on both HDMI and RGBHV
Why barco focus coils, or are you hoping to find the 909?
Posted: Tue Aug 03, 2010 1:53 pm    Post subject:
Yeah, the powerpoint, outlet, power outlet - whatever you call it Smile
Posted: Tue Aug 03, 2010 1:54 pm    Post subject:
Oh, I and I don't think you need to buy anything.
Do some testing first. Sort out if it is a ground loop.
dvh99
Posted: Tue Aug 03, 2010 3:37 pm    Post subject:
nope
https://www.curtpalme.com/forum_archived/viewtopic.php@t=22483.html
till
Posted: Tue Aug 03, 2010 4:00 pm    Post subject:
in my case it helped to turn some plugs around, maybe that can help in your setup too
jarseneau
Posted: Tue Aug 03, 2010 4:30 pm    Post subject:
Wow, what about Fleabay?
You shouldn't need it though if you have nothing odd in your signal path and lengths are less than 25 feet.
Jerry
