rdmiller
| Posted: Thu Jul 29, 2010 9:11 am Post subject: resolution and scan rate, how does a 1208x1024 = 1920x1080 |
my apologies if this has been answered before, I just cannot get my mind around this. I am looking though the projector rankings, and I see resolution, supported HD (720 vs 1080 i/p) and bandwidth. As I understand it, I can get a 1080i image with 36 khz, 47 khz will bring me 720p, and perhaps 72 khz would support 1080p.
I read max resolution listed, seems to average about 1280x1024. this seems a bit short of the 1920x1080 that represents HD. (btw, my skin crawls with the marketing of "true hd", but that is for another day). If I was to feed a 1080i image into one of the projectors rated for 1080i but a screen resolution that has a lower maximum would I lose data/ image compared to a projector that is rated beyond the 1980x1080?
oh yeah, while I have your eyes. contrast ratios. seems that the digital units are claiming 100,000:1 CR's. if the g90 only goes to a 30,000:1 CR then what is actually happening here?
thank you.
Richard Miller
akajester
| Posted: Thu Jul 29, 2010 1:36 pm Post subject: |
I can't comment on the first part, but contrast ratio has changed in the past few years. It's now called "dynamic contrast ratio" or a nice marketing shift to trick consumers into thinking their new panels can do black.
You can check out more here;
http://en.wikipedia.org/wiki/Contrast_ratio
dale
beun
| Posted: Thu Jul 29, 2010 3:37 pm Post subject: |
On the resolution issue, yes you will lose. The projector will scale the picture to make it fit into its native resolution. A 1280x1024 projector by the way sounds like a business projector to me, it's a 5:4 aspect ratio commonly used in computers so feeding that one a 1080i/p picture will result in big black bars on top and bottom.
_________________ ESL-0.5 Full Range Electrostatic Loudspeakers | RTC2200 Component to VGA Converter with Gamma Boost
JOneil
| Posted: Thu Jul 29, 2010 9:13 pm Post subject: |
| beun wrote: | | On the resolution issue, yes you will lose. The projector will scale the picture to make it fit into its native resolution. A 1280x1024 projector by the way sounds like a business projector to me, it's a 5:4 aspect ratio commonly used in computers so feeding that one a 1080i/p picture will result in big black bars on top and bottom. |
This is only if your talking a digital projector, not a CRT based one.
beun
| Posted: Thu Jul 29, 2010 10:26 pm Post subject: |
Guys, if you go back and read Richard's post again, I think the resolution question was specifically regarding the "Max Resolution" column on Curt's Projector Ranking "best/worst" list... In that case Richard, that column is essentially meaningless - at least in any technical context. You can pretty much ignore it.
No CRT projector will display a 1080i or 1080p picture "perfectly". With CRT's, we talk in terms of sharpness, or more technically "resolving power", which is how close to reproducing the source the projector can get. A high-end 9" machine can get very close (though it's not as sharp as a digital - which some of us actually prefer), an 8" machine is less sharp, and most lower-end 7" machines resolve well under half of a 1920x1080i signal. In less technical terms, 9" machines can do 1080p pretty well, 8" machines 720p or 1080i very well, and 7" machines a softer 1080i or 720p.
Read this:
http://www.curtpalme.com/CRTPrimer_14.shtm
On the contrast ratio question, basically the numbers really aren't comparable. It's a deep subject, but suffice it to say the two numbers weren't measured the same way. A G90 can be set up to display a nearly infinite on/off contrast ratio (though you wouldn't want to set it up that way. Digitals are now turning in some excellent on/off contrast numbers, not necessarily because they can produce a great black (many won't), but more because they're so damn bright.
There are plenty of articles to read if you want to read up on ANSI contrast versus dynamic (on/off) contrast. Google or search for a few discussions here or over at AVS Forum. Everything you ever wanted to know about sharpness, resolution, contrast, etc. can be found here, at AVS, or on the web.
