[Barco Cine 7] 0 degrees projection instead of 10.5.
Douma
Posted: Sun Jul 25, 2010 11:30 am    Post subject: [Barco Cine 7] 0 degrees projection instead of 10.5.
I have a 'like new' Barco Cine 7. Because my ceiling is too low, I can't mount the projector like it should, with the standard angle of 10.5 degrees. So I want to mount it on an 0 degrees angle. If I enter this data in LENS it gives me 0mm of vertical scheimpflug correction and 0.337mm of horizontal correction.
Is this correction with or without the 'three positions' spacer of the Cine 7?
betel
Posted: Sun Jul 25, 2010 1:42 pm    Post subject:
Assuming front projection:
I've been told if what you're trying to do is what I think you are, the image will reflect back into the lens causing image problems. Not sure what problems though. Have you considered floor mounting?
Ile
Posted: Sun Jul 25, 2010 8:33 pm    Post subject: Re: [Barco Cine 7] 0 degrees projection instead of 10.5.
I guess it's without Sheimpflug ring installed, because one ring solution can't have "zero" vertical setting and other Barcos don't have similar ring adjustment.
You need to add some other 0,337 mm shims under two red/blue lens bolts, those two bolts that are close to green tube.
0-0,337-0-0-0,337-0
0-0,337-0-0-0,337-0
I haven't find out that zero angle configuration add halo or other contrast issues to picture, so go ahead and try it. It's also only way to maximise phosphor usage. Thumbs Up
Posted: Mon Jul 26, 2010 12:13 am    Post subject:
Or you can tilt the screen 10.5 degrees
JustGreg
Posted: Mon Jul 26, 2010 6:17 am    Post subject:
You'll also be wearing a pyramid shaped pattern in the phosphor. I'm battling the same thing. If I lower the pj the rear riser center seat will only be able to accomodate short people. If I don't, my new tubes will have a weird raster wear pattern.
Sorry rear center seat person! Mr. Green
Greg
Posted: Mon Jul 26, 2010 7:10 am    Post subject:
Greg - Mounting the projector in the typical position most of us use them in results in the trapezoidal wear... A zero-degree offset will result in a perfectly rectangular raster and wear pattern.
The only way to use a zero-degree offset is if the projector is mounted straight out from the center of the screen... So, if the center of your screen is 3 feet from the ceiling, so would the center of the lenses be. Needless to say, not many people use a 0-deg offset.
I don't know enough about the Scheimpflug setup on the Barco Cine 7, but I would think you'd probably want to stay with the default offset, and drop the rear of the projector a little, and tilt the screen a little. You may have to do some shimming on the lenses to get best top/bottom focus if you don't have stepless Schempflug.
My G70 is flush against the ceiling at the front of the projector, but about 2-3" away from the ceiling at the back - that was to get the projection centered on my screen, which is probably only 3' from the ceiling. You have to tilt the screen or use stepless Scheimpflug to get focus ideal, but it works.
roland@b4
Posted: Mon Jul 26, 2010 9:13 am    Post subject:
Leave the spacers on the mid position
As already said the projector would normally point up at 10.5 degrees so even if your projector is completley on AXIS you will need to lift the back of the machien. (where the case splits gives you the vertical centre line view along that to get centre of screen)
Asuming your projector is on a tall table mount then you will have to place some spacers (a series of spring washers will give you variable adjustment) between the rear of the top of the lens and the tube mount.
Then just use those big plastic bolts/nuts to adjust the top bottom focus.
JustGreg
Posted: Tue Jul 27, 2010 5:27 am    Post subject:
My apologies for a quick hijack but I need to understand this. The Marquee Owners Manual states the feet are to be even with the edge of the screen regardless of ceiling or table mounting. That leaves the 10.5 degree built in angle to project to the center of the screen. The manual doesn't offer a zero degree mounting option. Question
I'm not doubting you but I can't see a pj being designed to use the tubes optimally if it has to be mounted with the tubes aligned with the horizontal center of the screen. I'm futzing with mine right now to minimize the trapezoid raster and have increased the angle of the screen to ~10 degrees. I think it looks like shat to be honest but I don't see any way around it.
The pj is ceiling mounted with the top edge of the screen and the base of the pj (no feet on it of course) only off by ~1". The pj body is leveled which leaves the factory built-in angle to hit the center of the screen. I'm hitting the center but still have to angle the screen and pj to ensure a good wear pattern on the tubes and good geometry at the screen. Hmmmm.
Greg
Phil Smith
Posted: Tue Jul 27, 2010 6:47 pm    Post subject:
I tilted the screen of my RP setup to reduce the angle to about 7 degrees. That surprisingly reduced the trapezoid shape of the raster a LOT, much more than I expected. At least for a G70, this was not a problem but a big plus. I'm sure Steve has similar results by dropping the back of his G70.
Not to state the obvious, but Scheimpflug is compensating for the angle of the tubes. Reducing that angle requires you to reduce the amount of Scheimpflug compensation. That can't help but be a good thing if your PJ can handle it.
Not real clear, but you can see the angle in my screen in this pic:
kschmit2
Posted: Wed Jul 28, 2010 5:51 pm    Post subject:
It should be similar with NECs: using the standard 11° tilt angle will result in a trapezoidal raster shape, while 0° tilt (i.e. with the rear of the PJ raised) results in as rectangular raster.
0° tilt is primarily intended for RP installs For your typical FP install it would result in the PJ being installed at a hight that is equivalent to the middle of your screen, which is fairly low for ceiling installs (or high for floor installs) Smile
Phil Smith
Posted: Wed Jul 28, 2010 6:52 pm    Post subject:
Yes but you can reduce the angle of a FP PJ by dropping the back like Steve did. That does however require the screen to be mounted higher.
I wasn't able to do a zero degree RP setup because the PJ is mounted in the garage. I needed the garage to still function as a garage.
VideoGrabber
Posted: Sat Jul 31, 2010 7:06 am    Post subject:
Phil,
that garage-RP is pretty cool, and quite inventive. I've never seen anybody do anything like that before (use a garage as a hushbox), but it does answer the question of what do you do with all the space behind a huge RPTV. Smile I see you even provided doors for rear-access to the back of your A/V gear. That's definitely thinking outside the box.
With the PJ being in the (heated?) garage, did you ever run into any problems that resulted from that mounting location? (Debris in the air, fumes, lights from the wife pulling her car in at night... Very Happy)
- Tim
Posted: Sat Jul 31, 2010 10:37 am    Post subject:
This sounds like one of those situations where a factory authorized dealer/installer would come in and say NOPE. The application is not suitable for the installation of a CRT projector and refuse the job.
Post a couple of pictures of the room showing where you want the projector and screen to end up. A picture is worth a thousand words.
Douma
Posted: Fri Aug 06, 2010 10:29 am    Post subject:
Thanks for all the replies. After some more calculation I ended up with a projection angle of 8 degrees. I removed the scheimpflug rings and according to the output of LENS I fitted the right amount of small washers.
The Barco now has it's own custom made ceiling mount and hangs rocksteady.
So it was a case of tempest in a tea pot. Sadly I ran into some other problems after the first rough setup:
http://www.curtpalme.com/forum/viewtopic.php?p=262185#262185
