astig setup on barco 1209s
dvh99
Posted: Fri Jul 23, 2010 11:12 pm    Post subject: astig setup on barco 1209s
does the astig setup from a barco differ from a marquee.
i didnt find anything in the installation manual but i guess the barco has cpc magnets as well that can be controlled on the neck of the tube.
i will be helping someone again with setting up a b1209s and i noticed today that all astig dots are oval.
is it also possible to store different setups with different raster sizes on the barco.
and the last question what is the equivalent on the barco for the blanking on the marquee.
and can these blanking values be stored in different memories.
this model is with continuous scheimpflug.
dennis
Ile
Posted: Sat Jul 24, 2010 11:42 am    Post subject:
If you checked with Barcos internal pattern and 16:9 screen, they should look oval because pattern are 4:3. Very Happy
Use correct AR test pattern from source or test disc.
Tubes mechanical settings found on last two pages
http://www.curtpalme.com/docs/BarcoGraphics808s_CRTReplacementProcedure.pdf
Zone Astig from service menu are common for all sources, memory block have own blanking settings under geometry.
dvh99
Posted: Sat Jul 24, 2010 11:55 am    Post subject:
hi ile it was setup with 4:3 ratio.
i didnt know where to look, nothing in the installation manual thanks.
