jeffslife
| Posted: Thu Jul 22, 2010 1:22 am Post subject: dioes digital out (orange) need a special cable EDIT-PROBLEM |
does the digatal out need a special kind of cable or will a standard rca work? thanks in advance i know this is not the correct forum for this question but i cant seem to get back to the list page.
jeff1slife@yahoo.com
CZ Eddie
| Posted: Thu Jul 22, 2010 1:30 am Post subject: |
Digital coaxial audio can use a standard RCA cable, yes.
_________________ Back after a digital sabatical.
| Posted: Thu Jul 22, 2010 1:32 am Post subject: |
Not only can it, it should... Coaxial SPDIF is designed around the same 75-ohm coaxial cable that composite/baseband video uses.
How come you couldn't find the index again, Jeff? Do you see the links at the top and bottom of every thread that says "CurtPalme.com Forum Index" ?
jeffslife
| Posted: Thu Jul 22, 2010 2:40 am Post subject: |
sorry, explorer crashed now my wi fi is getting iffy too. gremlins i geuss
i have another question on the same subject though if nobody minds
i have 2 digital outs to connect and only 1 input on my amp
so am i stuck with having to decide or is it possible to hook up both
i have several other problems, but ill get into those later
thanks for everything you guys are the best !
p.s. yeah i see them now.maybe im the gremlin
| Posted: Thu Jul 22, 2010 2:53 am Post subject: |
If you have more sources than inputs on your receiver/preamp, you can use an outboard switch... There are lots of options, but they don't get much cheaper than this component switch from monoprice:
4 Port Component Video Switch w/ IR Learning
You might also be able to find a composite video switcher that would also work for next to nothing on fleabay.
| Posted: Thu Jul 22, 2010 2:56 am Post subject: |
| jeffslife wrote: | sorry, explorer crashed now my wi fi is getting iffy too. gremlins i geuss
p.s. yeah i see them now.maybe im the gremlin |
You need to use a 75 ohm digital or even a video RCA cable will work, but use a good quality
cable.
Look for an older Composite or component video switcher . If using a component switcher for example use green in and green out, that is, the same color. look for the old monster branded Entec switchers, i had the component one and used it for that purpose for a while before I bought a B&K Digital switcher that also had optical and converted to coax.
here is a review of this old switcher, it really did a great job back in 1998 and should do what you want.
http://www.hometheaterhifi.com/volume_5_3/entechdirector.html
id look on e-bay or craigs list.
| Posted: Thu Jul 22, 2010 2:58 am Post subject: |
Mwuuhhahahah... Beat ya to the punch Athanasios!!!!
jeffslife
| Posted: Thu Jul 22, 2010 5:07 pm Post subject: |
THANKS EVERYBODY FOR ALL YOUR HELP, PROBLEM SOLVED AGAIN. JEFF
