dvh99
| Posted: Wed Jul 21, 2010 2:35 pm Post subject: problem after doing the faint line tech bulletin. |
after doing this tb to my vim the raster that is not used lights up faint. (not the grid but the raster)
i used 1.5Mohm just like in the tb.
vim: 01-260335-2p
50-2035-02p
| Posted: Wed Jul 21, 2010 2:53 pm Post subject: |
I think that's normal. I had to set my brightness much lower after doing the faint-line fix.
dvh99
| Posted: Wed Jul 21, 2010 2:57 pm Post subject: |
so you mean that for instance with a setting of 30 i get the same brightness as 50 after the mod.
| Posted: Wed Jul 21, 2010 2:58 pm Post subject: |
Yes, that is normal. I use 2.2m resistors on my latest VIM mods. I'm using 2.2m there instead because I'm also using 2.2m in another stage of the VIM.
dvh99
| Posted: Wed Jul 21, 2010 3:12 pm Post subject: |
i have played with the g2 settings now and the raster not used is now gone, it just needed a few clicks.
this way my brightness remains on 50 but i will play with it later tonight when its dark.
dvh99
| Posted: Wed Jul 21, 2010 5:01 pm Post subject: |
curt if you are reading this maybe you can add that colour temperature setup needs to be redone after this fix.
