DIY Torus Screen
Kiev Savoie
Posted: Mon Jul 19, 2010 1:47 am    Post subject: DIY Torus Screen
I've done a couple of searches for instructions on making a Torus Screen with out much luck. I've found some interesting threads but nothing that shows how to design and then build one. Anyone got a link?
Posted: Mon Jul 19, 2010 2:37 am    Post subject:
Try these:
http://archive.avsforum.com/avs-vb/showthread.php?threadid=216010
http://archive2.avsforum.com/avs-vb/showthread.php?threadid=467141
http://archive2.avsforum.com/avs-vb/showthread.php?t=541964
http://archive2.avsforum.com/avs-vb/showthread.php?p=5627244&&#post5627244 (Paul may have an updated version)
http://www.avsforum.com/avs-vb/showthread.php?p=10171052&posted=1#post10171052
Kiev Savoie
Posted: Mon Jul 19, 2010 8:51 pm    Post subject:
Thanks Gary!
I just read through most of it and it seems totally do-able. I'm wandering what the depth of the focal field is on a G70 though, the Torus lite concept sounds nice but it just seems like I could push the curves a little deeper for better uniformity/gain and sill get an acceptable convergence. The range i'm seeing so far for 100"+ wide screens has been between 3.5" to 7.5" on the horizontal, so maybe something between those two would work well...
Posted: Fri Jul 23, 2010 2:13 pm    Post subject:
I think Vince had the G70 at a little more extreme angle. If you mount it with less angle, then you have less issues. Check AVS for a thread I started where there was a list of Torus screens and equipment that everyone was using.
Kiev Savoie
Posted: Fri Jul 23, 2010 11:40 pm    Post subject:
Sounds good! Thumbs Up
davidcrowe18
Posted: Wed Aug 18, 2010 11:19 am    Post subject:
The torus works great. I made one for my D50 and two for my 1292s. Each one was larger than the last. Let me know if you need any help.
dvh99
Posted: Sun Nov 28, 2010 8:17 pm    Post subject:
anyone here that has a angle calculator for torus screens.
if someone would write a how to build a diy torus, that would be great.
and where can i get the liquid foam to hold the fabric in place.
did you finish your torus screen, kiev savoie?
dturco
Posted: Sun Nov 28, 2010 10:36 pm    Post subject:
See Gary's post above ^ 5 up ^ AVS link 5627244 for the Math and the rest for General info. Wink
http://www.hulu.com/firefly
