jeffslife
| Posted: Fri Jul 16, 2010 5:44 pm Post subject: sir t160 what kind of adapter should i use |
i got a samsung t160 tuner and i dont know what to do next. it has dvi/hdcp out and rgb out and component out which is best to use and how can i hook it up to my fury 3 should i use two hdmi cables or get some kind of switching device and if so what? i need reasonable prices i havent worked in a year and a half, but i still want it to have functionality. Thanks in advance for any help.
jeff1slife@yahoo.com
thanks again jeff
ps i love this site!
jkruger
| Posted: Fri Jul 16, 2010 7:06 pm Post subject: |
I used a dvi - hdmi cable to go to the fury.
jeffslife
| Posted: Fri Jul 16, 2010 7:17 pm Post subject: |
ok heres the rub i need a 35 ft cable and as i have discovered since last week a good one. (cost 60 bucks plus shipping) is there some kind of resonably priced switching device that would work?
jkruger
| Posted: Fri Jul 16, 2010 9:46 pm Post subject: |
I have a hdmi switcher in between the ts-165 and the fury. The powered hdmi matrix that I showed you last week. Run a short dvi-hdmi cable into the switcher and then the long cable out to the projector. The switcher is powered for less signal loss.
jeffslife
| Posted: Fri Jul 16, 2010 10:07 pm Post subject: |
thanks ! got it ordered through monoprice will be here tuesday. Cant wait. i really appreciate all your help.
thanks so much problem solved. jeff
paw
| Posted: Tue Jul 20, 2010 3:45 am Post subject: |
You know the t160 will output HD over RGB? You can feed this directly into your PJ. You should be able to pick up various RGB switchers for a reasonable price.
You didn't mention your other sources. I'm assuming a blu-ray player. You should be able to go
blu-ray -> hdmi cable -> fury 3 -> rgb cable -+ switcher -> rgb cable -> PJ
........................................t160 -> rbg cable -+
_________________ Aubrey
