fbjr1
| Posted: Mon Jul 12, 2010 5:26 pm Post subject: barco 800 whites turning yellow |
just setting up my "new" iscan hd+ noticed that in some pictures that the was a slight change in the whites to a yellowish tint. switched over to a channel (HSN) that has a normal white background and it is more pronounced there. starts out white then turns yellowish. also noticed if i switched channels then switched back it startes out white then drifts back to not so white/yellowish.
Iscan?
tube?
board?
scan rate?
any ideas?
thanks again
frank
_________________ BG 800
iscan pro
Directv
| Posted: Tue Jul 13, 2010 2:02 am Post subject: |
How high have set the contrast? and are any off your input devices pushing the contrast level up??
fbjr1
| Posted: Tue Jul 13, 2010 3:55 pm Post subject: |
will check that tonight. have it all unhooked while i recable through the ceiling.
thanks
iscan pro
Directv
fbjr1
| Posted: Thu Jul 15, 2010 3:53 pm Post subject: |
thanks that did the trick. contrast was up way to high on barco.
love this board.
frank
iscan pro
Directv
