antorsae
| Posted: Sat Jul 10, 2010 9:52 pm Post subject: Marquee red convergence shaking |
I'm back at playing some Xbox 360 games so I set up my Marquees to play. Resolution is 720p60 and one projector exhibits a very weird behavior: the red color is not totally stable.
It "shakes" horizontally a bit especially in the top left of the screen (my projector is ceiling mounted). Green and Blue are solid but red shakes. I NULLed convergence electronically and it still shakes.. so basically if you put the convergence grid you see it the red shaking a bit (enough to be noticed).
I've only noticed this behavior at this resolution/refresh rate.
Any ideas/hints?
Rgs - Andres
| Posted: Sat Jul 10, 2010 10:14 pm Post subject: |
disconnect the convergence and astig cables going to the tube. Does it still shake?
antorsae
| Posted: Sun Jul 11, 2010 3:28 pm Post subject: |
Will try later tonight... AFTER THE WORLD CUP FINAL!!!!!!
I'm not a big soccer fan but Spain being in the finals has transformed me!
antorsae
| Posted: Fri Jul 16, 2010 6:26 am Post subject: |
I did perform the following experiments:
- I removed the astig and convergence (for the red tube). Red still moves.
- I swapped the VIM. It still moves.
Upon closer inspection I can see that is not only red that shakes but also green (and possibly blue - although I didn't check).
I plan to:
- Unplug CCM, ACON
- Swap HDM
- Clean CLM contacts, etc.
Changing CLM is my last resort as I'd need to make a backup of the unit before doing so, etc. etc.
Any more ideas?
1031
antorsae
| Posted: Fri Jul 16, 2010 4:30 pm Post subject: |
Thanks Athanasios - I'll try tonight.
1031: This happens with 720@60 and 1080x820@72. Since the pixel clock is not very high, I just used GTF for those resolutions.
antorsae
| Posted: Fri Jul 16, 2010 10:05 pm Post subject: |
I did a few more tests:
- Unplugged all convergence/stig (in fact I just unplugged the flat head cable connecting the two boards conv + stig) => SAME ISSUE.
- Unplugged ACON + CCM => SAME ISSUE
It looks like it happens on green more severely and I've also noticed that the green has some horizontal noise (like minor glitches that shift lines of the image horizontally).
Definitively it looks like noise.
Ideas before swapping CLM?
dvh99
| Posted: Fri Jul 16, 2010 11:55 pm Post subject: |
| antorsae wrote: | Will try later tonight... AFTER THE WORLD CUP FINAL!!!!!!
I'm not a big soccer fan but Spain being in the finals has transformed me!  |
just kidding
holland played terrible and made too many fouls, congratulations although i still hate they lost.
dvh99
| Posted: Sat Jul 17, 2010 12:06 am Post subject: |
i have read that q501 on the hdm can cause some problems, it is a 2n7000 transistor and is on the daughterboard of the hdm.
replace c50 on the hdm too that is a 220uf 160volt cap.
or try soldering the chips on the dpb(daughterboard clm) or clean their pins.
antorsae
| Posted: Sat Jul 17, 2010 7:22 am Post subject: |
I will clean (w/ stabilant) DBP & CLM pins and then swap HDM.
antorsae
| Posted: Sat Jul 17, 2010 7:24 am Post subject: |
I have not (but I did unplug the stig and convergence boards altogether - so I guess they are not the culprit...). But it seems like a good idea!
