Toshiba 40H80
Bob_Collins
Posted: Fri Jul 09, 2010 12:09 am    Post subject: Toshiba 40H80
I have a Toshiba 40H80 set (RPTV with component video inputs) which is still going strong and has served me well thus far. This set was one of the first models in which Toshiba hid or disabled the "designer mode" where the majority of tweaks are done, and from what I understand it instead has only the standard "service mode" and an "ADDR mode" where you can make tweaks, but I am missing the map to the ADDR mode which would tell me the locations for the various settings and provide the link from address to the name of the option being changed.
Does anyone have a map of the ADDR mode for the 40H80 set (NOT the TW series)? Does anyone have any tips or tricks for the 40H80 set? Does the 40H80 have any type of CMS (even a very rudimentary one)?
Also, since hooking up my new Oppo BDP-83 and being able to actually check the 1080i signals, I noticed that the size was off a bit. Using the Service mode I adjusted the height & width, and have the overscan set to approx. 5% on all sides, but in doing so, the horizontal lines across the top are now wavy. Again, without any further information on the ADDR mode, I have no way to tweak anything to correct this and the offerings in the service mode seem of no help here.
Any and all assistance, tips, or information would be welcomed, and definitely appreciated.
Thanks in advance!
