Several issues with BG808s
opv
Posted: Thu Jul 08, 2010 7:29 am    Post subject: Several issues with BG808s
Hi everyone, this is my first message here.
My name is Or, I am enjoying a BG808s for the past 5 years.
I've recently switched from vertical mounting to table top and I have some issues with the setup.
The video source is an Istar H6 media player (similar to popcorn A110) connected via HDMI to a Pioneer Vsx-LX70 AV receiver, connected via HDMI to a Moome Ext card V2 and from the Moome card to the PJ using RGBHV. the resolution is 1080P@ 50Hz
Here is a list of the issues I came out with:
1) Picture is rotated: I've measured the PJ distance to the wall and I checked that it is leveled. Yet, the picture is rotated and I have to set the horizontal skew to 99 in order to get a leveled picture. What could be the cause for this rotation?
2) Noise at the picture top: I have noise in the top of the picture, something like moving vertical lines visible in bright scenes.
3) Halo around lines: When I'm very close to the screen, I can see a halo around thin lines. I really don't know if it's normal or maybe a focus issue.
That's it; I'd love to hear your opinions regarding these issues.
Or
Decibel
Posted: Thu Jul 08, 2010 8:43 am    Post subject: Re: Several issues with BG808s
You must read installation manual, from page 4-1 to page 4-3.
You must change scan switch for set projection configuration.
Try to move raster from bottom to top (geometry menu/raster shift)
Domenico (Barco fan!)
opv
Posted: Thu Jul 08, 2010 8:47 am    Post subject: Re: Several issues with BG808s
Thank you for the reply,
I have read the manuals and changed the scan switches, the picture isn't up side down, it's rotated by ~20 degrees
Regarding raster shift, I'll try that later when I'm home.
Decibel
Posted: Thu Jul 08, 2010 8:58 am    Post subject: Re: Several issues with BG808s
All colors or green only?
Check deflection yokes.
Set horizontal skew to mid position (49)
Loose the screw of deflection yoke and rotate it, till horizontal line is levelled (center of the screen).
See image
Sorry for language Wink
opv
Posted: Thu Jul 08, 2010 10:00 am    Post subject:
All colors, not just green. is the deflection yoke answer still relevant?
Decibel
Posted: Thu Jul 08, 2010 10:56 am    Post subject:
See previous picture.
There is one yoke for each tube.
Set horizontal skew at midposition (49) in geometry menu and rotate each yoke till horizontal line of the relative color is levelled.
I think that you must reset convergence also.
opv
Posted: Thu Jul 08, 2010 11:06 am    Post subject:
I understand, it's just seems really strange that all three yokes moved to this strange position. by the way, is there any risk of electrical shock when moving these yokes while the PJ is on?
Decibel
Posted: Thu Jul 08, 2010 11:15 am    Post subject:
Yes is strange but when change projection configuration (ceiling to table) the best way is completely reset convergence and geometry.
YES!!! ATTENTION!!!
opv
Posted: Thu Jul 08, 2010 11:40 am    Post subject:
YES!!! ATTENTION!!!
I did reset the geometry and convergence, I just don't understand why the picture is rotated when all the settings are set to mid.
If I do decide to touch the yokes, you have any safety advice for me?
Decibel
Posted: Thu Jul 08, 2010 12:02 pm    Post subject:
Don't touch cables, loose screw with little screwdriver and turn the yoke touching the grey plastic.
opv
Posted: Thu Jul 08, 2010 12:36 pm    Post subject:
OK, I'll keep that in mind, thanks.
Any ideas regarding the third issue?
Decibel
Posted: Thu Jul 08, 2010 12:46 pm    Post subject:
I think focus issue, you must make optical focus and sheimpflug.
Crt is not digital vpr, when change position you must resetting any mechanical, optical and electronic regulations.
I hope that you understand.
opv
Posted: Thu Jul 08, 2010 12:58 pm    Post subject:
Maybe I wasn't clear, I did a totaly new setup after moving to table top mounting.
I'm a CRT PJ owner for quite a long time and I know the basics (at least I think).
The issues I pointed here are only problems I didn't find the solution for after trying many options.
I appreciate the help and I'm looking for more ideas, things that I haven't thought of.
Decibel
Posted: Thu Jul 08, 2010 1:14 pm    Post subject:
Don't worry: my language is simple, directed and essential because I don't speak well in english.
Posted: Thu Jul 08, 2010 3:04 pm    Post subject:
Make sure the projector is level before turning those yolks. Who set up the projector when it was on the ceiling? It may not have been installed level at one time and the yolks were all turned. And now if its level could be why they are all off. You can wear a rubber glove to move them to avoid a shock but still be careful where you touch. A pointy part can still puncture the glove. But the shock wont hurt for to long, lol. Laughing If I had a nickle for everytime I've been wacked....... well you get the point. Shocked
opv
Posted: Thu Jul 08, 2010 3:17 pm    Post subject:
I did all the setups myself, and I never touched the yokes.
I measured distance from the side walls at the projector front and at the projector's back plus I measured the distance to the screen from the right side of the PJ and from the left side, everything seems to be leveled.
I also used a level above the PJ and it looks OK; it's a small level so there may be a error here.
Any other measurements I can take to make sure it's leveled?
Posted: Thu Jul 08, 2010 3:25 pm    Post subject:
I have had skew issues on BG808s, even when everything is stock and not touched after it leaves the factory.Rotating the yokes isn't a big deal. Chances are you will need to offset she skew a bit on the H an v axis, then use the skew/tilt adjustments to correct them, but you'l be at say 60-70 instead of 99. Seems to be a normal issue with BG808 sets, especially the 's' models. Not sure why.
as for the lines on the top, can you blank those out with the blanking controls? If not, you can take the lenses off and mask them off with black electrical tape, as long as they are outside the image.
as for the haloing, it's probably halos due to the non LC housing. can you capture the issue in a picture?
opv
Posted: Thu Jul 08, 2010 3:31 pm    Post subject:
Thanks Curt,
Regarding the lines on top, since the lines are in the picture area I'll try to change the raster shift and see if I can get them out of the picture.
Regarding taking a picture of the screen, I have a problem, I have a simple compact digital camera and I don't know how to avoid getting running lines when I take a picture of the screen. any advice here?
opv
Posted: Fri Jul 09, 2010 1:38 pm    Post subject:
OK, some updates
Regarding the noise in the top of the picture, it is somehow related to the top blanking mechanism. when I set the top blanking to the maximal value above the picture I get the noise, when I set it to lower values there is no noise.
Regarding the halo, I switched resolution to 1080i@50Hz and ran a full setup, I found out that the picture is shaking and the halo appears only on vertical lines because the picture is shaking up an down. could this be the fault of the deflection yokes not firmly connected?
