Dwin HD700 Stack?
jkruger
Posted: Thu Jul 01, 2010 7:20 pm    Post subject: Dwin HD700 Stack?
Someone local to me is considering a stack with two Dwin 700's. They can do 1080i, and are very quiet. Has anyone here done it? I know most guys would say to use a better projector but he already has one and if he bought mine he might get a pretty good setup for really cheap.
Posted: Thu Jul 01, 2010 7:29 pm    Post subject:
That should work fine. With their point convergence, each set should have enough range to do it.
jkruger
Posted: Thu Jul 01, 2010 7:32 pm    Post subject:
Side/side or top/bottom?
benareeno
Posted: Fri Jul 02, 2010 12:19 am    Post subject:
the dwins already put out a lot of light...a stack might look like a plasma!
Posted: Fri Jul 02, 2010 12:33 am    Post subject:
I would do top/bottom.
That sounded wrong. Smile
benareeno
Posted: Fri Jul 02, 2010 1:00 am    Post subject:
nice one!!
Posted: Fri Jul 02, 2010 1:26 am    Post subject:
That's how most Porn movies start Wink
Posted: Fri Jul 02, 2010 1:41 am    Post subject:
AH HAAAAAAAAAA!!!!! Now we know what you watch on that big blend!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Laughing
jkruger
Posted: Fri Jul 02, 2010 2:29 pm    Post subject:
That's what I was thinking. 1100 x 2 is a lot of lumens. He could almost watch that in daylight. Smile
jkruger
Posted: Sun Jul 04, 2010 1:48 am    Post subject:
I would do top/bottom. Smile
Is that because they don't have enough scheimpflug? He may not have high enough ceilings for top/bottom.
Posted: Sun Jul 04, 2010 2:55 pm    Post subject:
You can do plenty of scheimpflug with the Dwins. Just adjust the nuts that hold the lenses on those long bolts and you'll have more adjustment than you get with most "real" scheimpflug setups. It's a PITA but it can work.
donaldk
Posted: Sun Jul 04, 2010 9:22 pm    Post subject:
You could do a litteral stack, provided the adjustments are there. Or tilt the projectors to go for near(!) on-axis projection.
