Sucsess short lived... :( HV dropping out 2 sec after pwr on
Posted: Sun Jun 27, 2010 10:46 am    Post subject: Sucsess short lived... :( HV dropping out 2 sec after pwr on
Anyone know what would cause the HV to switch off on a Sony VPH 1001-QM right after start up?
Turning on the set it all fires up fine, and after 2 seconds or so, you hear the sound of the HV turning off ( the same sound youd normally hear when you turn the set off, static sound )
Nothing on the tubes for obvious reasons. The rest of the set stays running.
Thanks in advance Smile
JustGreg
Posted: Sun Jun 27, 2010 9:06 pm    Post subject:
Your problem sounds very familiar to the problem I'm having with my 8500. I haven't done it yet but Nash suggested I isolate each tube one at a time by removing the neck boards. Would that same test work on a Sony? I should think nb's are all similar in function except perhaps they don't control HV sensing shutdown like a Marquee?
He said to remove all the cabling from the nb before removing it from the tube neck. I can't remember if he said to remove the HV lead from the splitter but I'm going to anyway. I'd rather have nothing connected to the tube at all.
Greg
Posted: Mon Jun 28, 2010 8:46 am    Post subject:
No idea if that will work or not, at one point i did get two bright flashes and a couple pops from the blue another time i got the same from the green, but i seriously doubt that was terminal or even did any damage, cause after that i checked a heap of connections and it fired up perfectly. I wouldnt think its the tubes, they displayed a perfect picture until this issue, and when i managed to get the HV to stay in the other night they were perfect too.
