copy format ?
jeffslife
Posted: Tue Jun 22, 2010 7:50 pm    Post subject: copy format ?
i have a zenith 895 pj and a zenith 900 pro x pj . on the 895 when you get it all converged correctly which is no small feat for me at least, you can copy the format from 4:3 to 16:9 or letterbox format and the convergance is great. When i tried to use this feature on the 900 i lost all convergence even on the format i was copying from. any help would be appreciated i am a newby to this so please use small words. Thanks in advance Jeff slife
jeff1slife@yahoo.com
Posted: Tue Jun 22, 2010 8:21 pm    Post subject:
It's possible that the memory chip is corrupt, so I'd simply set up the convergence twice and call it a day. I personally don't use the copy command, but have seen failures like this on the PRO 900s and 895s. If it saves one memory when powering down, then I'd just forget about the copy function.
jeffslife
Posted: Tue Jun 22, 2010 8:55 pm    Post subject:
ok thanks again for the info
you guys are the best
when i get some cash rolling in again i plan on upgradeding through curt palme
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
We are ALL job creators !
jeffslife
Posted: Tue Jun 22, 2010 8:56 pm    Post subject:
