| Posted: Mon Jun 21, 2010 5:07 pm Post subject: Lumagen XE (maybe XS, XD) to Support 3D Very Soon!!! |
3D from the Radiance is not yet a given so no promises yet. Lumagen may still encounter an insurmountable obstacle that kills the project. But that being said...
I just spent a while talking to Jim Peterson of Lumagen. He informed me that the next major release being worked on for the Radiance processors is 3D. Right now everything is tentative and not defined, but here is the information I have now.
-The 3D upgrade will cost $199.
-The processors should be set to 120Hz output for CRT applications.
-The upgrade is scheduled to be released in one month (hopefully).
-Lumagen may still run into problems that spoils the project entirely, but right now things are looking good.
Here are some bigger questions...
-The trigger output on the XE and XD might work as an output to an IR transmitter to drive 3D glasses with CRT!!!
-Lumagen will only attempt this if there is demand, so if you want this triggered glasses support (and all CRT people should) please post your comments to this thread and I will pass them along to Jim.
-Since the XS does not have a trigger, the XS is not planned to drive glasses at this time.
-The XE and XS have a better chance of working 3D in the end because they have the newer chips.
-But Lumagen will try and make the XD run 3D as well.
-If the IR glasses trigger works, it will work on the XE and XD, if the XD can run 3D at all.
I'll be doing some testing here for Lumagen soon I am sure. I have a media server that supports 3D and an XE here along with my G90. I already have 120Hz running and set up on the G90.
Please feel free to post any questions or comments and I will try and answer them (if allowed by Lumagen) or I can ask Jim if I don't know the answers. This is still Alpha development right now so I am not allowed to disclose all that I know and Lumagen has not divulged everything they are working on to me in its entirety.
And like I said, 3D from the Radiance is not yet a given so no promises yet. Lumagen may still encounter an insurmountable obstacle that kills the project. But right now Lumagen believes that this will work.
Last edited by CIR Engineering on Mon Jun 21, 2010 5:59 pm; edited 1 time in total
dvh99
| Posted: Mon Jun 21, 2010 5:22 pm Post subject: |
if one would blend 2pj`s can the lumagen handle 2 times 1920/2 + 5% overlap *1080 @ 120hz on 2 hdmi outputs?
| Posted: Mon Jun 21, 2010 5:26 pm Post subject: |
| dvh99 wrote: | | if one would blend 2pj`s can the lumagen handle 2 times 1920/2 + 5% overlap *1080 @ 120hz on 2 hdmi outputs? |
I talked to Jim about this and the short answer is no, but yes... What you are asking actually has digital applications as well. He said that they may try and support two projectors in a later release, but the catch is that you would need two identical Radiance processors to do it. You would need two processors instead of simply using the two HDMI outputs.
| Posted: Mon Jun 21, 2010 5:37 pm Post subject: |
for a blend all you need is the a lower res any how, i use 1064x800p@72 hz now from my Tv-One I tried it at 96 hz with that res and it still looked good, a bit softer but very smooth and I tired 120 hz with the same progressive scan rate, this is where it softened up. I will have my XS's before the tv ones.
A stack would be totally different, maybe have each image shut off to each PJ , this would then replace the glasses as now the PJ's them selves would become the shutters . now the speed of the image flash is whats critical, or it might not work this way at all.
Sparky015
| Posted: Mon Jun 21, 2010 6:01 pm Post subject: |
Cool, I called this in the 3D thread! I should be a marketing guy!
_________________ ~Paul
| Nashou66 wrote: | for a blend all you need is the a lower res any how, i use 1064x800p@72 hz now from my Tv-One I tried it at 96 hz with that res and it still looked good, a bit softer but very smooth and I tired 120 hz with the same progressive scan rate, this is where it softened up. I will have my XS's before the tv ones.
Nashou |
What Jim was talking more about with dual Radiance units is actually using them with a polarized screen. This may not work at all with CRT because I think we would also need polarized lenses? I don't know?
Lots of questions remain.
dvh99
| Posted: Mon Jun 21, 2010 10:00 pm Post subject: |
the ultimate device would be of course a vp that can blend and send the required resolutions over the 2 outputs and support 1080p@120hz on 1 output (this of course for the next gen dig pjs).
kal Forum Administrator
| Posted: Thu Jun 24, 2010 12:30 pm Post subject: |
| dvh99 wrote: | | the ultimate device would be of course a vp that can blend and send the required resolutions over the 2 outputs and support 1080p@120hz on 1 output (this of course for the next gen dig pjs). |
Lumagen is thinking of supporting stacked digital projectors for 3D. However, the digitals don't need to be supplied with 120Hz because they will internally up the refresh rate from the original 1080p 24Hz. This config would be similar to what you get in theaters now with polarized glasses. However, if Lumagen decides to deploy this feature you will need two Radiance processors stacked to do it. The Radiance processors only support the same video output on both HDMI outs. IE they can not display two different output configs through the two HDMI outs simultaneously. The hardware in the existing Radiance models does not support it.
Sparky015
| Posted: Thu Jun 24, 2010 1:26 pm Post subject: |
Ok, so I am saving my pennies for a Radiance, but I don't need all of the inputs and outputs of the XE, the XS (more specfically the XS+) is perfect for me and the number of sources I have. I see that it doesn't have the external trigger, so 3D is out? Is there anything else about the XE that is different from the XS?
This post should probably be in the Radiance thread and maybe I need to call Lumagen myself, but before I make an investment like this, it would be nice to know what Lumagen is going to do for updates and upgrades for it in the future, if any.
Boilermaker
| Posted: Thu Jun 24, 2010 2:23 pm Post subject: |
I have seen in numerous posts about 3D for crt projectors discussions about the bandwidth limitations. On several of these posts I have seen recommendations for using an interlaced signal at 120 Hz. which would effectively cut the bandwidth requirement in half.
BUT - I can see a problem with using interlaced signals that hopefully someone can help me understand. Since the interlaced signal is actually two separate 1/2 resolution images (even & odd lines) each scanned during 1/2 the total time period; when using shutter glasses, depending on the shutter rate, either only 1/2 of the resolution will be shown as the shutter will switch eyes or there will be no 3D effect as the even lines will be seen by one eye, and the odds with the other.
Sorry that I am not able to describe very well what my concern is, but maybe someone can describe it better. I have even confused myself!
I do have some interest in trying 3D because, as Athanasios pointed out, with a blend, you have already cut down the bandwidth issue by almost 2 to 1.
Bob
| Posted: Thu Jun 24, 2010 7:12 pm Post subject: |
Guys!
I still think home 3D will be a short-lived fad, forgotten in a year or two. First, CRT projectors will need P43 green phosphor or the lag problem will put ghosts all over the screen. A nine inch Marquee tube in P43 is near $4400, approaching the value of a used projector itself. P43 gives up about twenty percent of the light output of standard green. You will lose thirty or forty percent light output through polarizers or shutter goggles. Polarizing requires metal foil screens. Shutter goggles become extremely uncomfortable after fifteen minutes, worse if the viewer wears them over regular eyeglasses. The whole thing is way impractical. Even for free, I don't want 3D.
dvh99
| Posted: Thu Jun 24, 2010 10:46 pm Post subject: |
i have a p43 green tube so i think i will give it a go and see the effects.
any recommendations on movies on which the 3d is implemented well.
| Posted: Fri Jun 25, 2010 11:45 am Post subject: |
| Sparky015 wrote: | Ok, so I am saving my pennies for a Radiance, but I don't need all of the inputs and outputs of the XE, the XS (more specfically the XS+) is perfect for me and the number of sources I have. I see that it doesn't have the external trigger, so 3D is out? Is there anything else about the XE that is different from the XS?
This post should probably be in the Radiance thread and maybe I need to call Lumagen myself, but before I make an investment like this, it would be nice to know what Lumagen is going to do for updates and upgrades for it in the future, if any. |
I would call Lumagen if I were you. At this point there is no plan to add a trigger to the XS unit as it would require a new board design and also a 12 volt power supply like the XE. Also part of the point of the XE is that it has more features and adding the same features to the XS would defeat the purpose of having two different products
There are a few differences between the XE and XS including HDMI pip (picture in picture) with the XE and of course the trigger outputs.
| Posted: Fri Jun 25, 2010 11:46 am Post subject: |
| Boilermaker wrote: | I have seen in numerous posts about 3D for crt projectors discussions about the bandwidth limitations. On several of these posts I have seen recommendations for using an interlaced signal at 120 Hz. which would effectively cut the bandwidth requirement in half.
Bob |
I know what you are talking about and I think this is one reason Jim feels strongly that a resolution less than 1080p will likely be better.
| Posted: Fri Jun 25, 2010 11:51 am Post subject: |
| Tim in Phoenix wrote: | Guys!
Hi Tim,
You know I respect you and usually value your input. However, I would appreciate it if we can keep this thread on track and discuss the Radiance processors and 3D without the distraction of the virtues of 3D in general. At this point there are indeed a lot of unknowns. Yes, you may need a P43 phosphor, but you also may not. Yes 3D may be a fad, but it might not be. Yes, it might be dim on CRT, but then again it might not be that bad. And no, I don't really think I will personally much enjoy 3D in my own home... but I sure do want to try it for some reason... pushing the bubble as far as I can
I see it more as a demo idea for friends and clients who come by to see the system. I don't know if I will watch an entire movie that way, but it might be cool to look at for an hour here or there and show other people. But then again it might be awesome and I always want to use it whenever I can.
