Marquee 8500-Boards to disconnect for initial setup
JustGreg
Posted: Sat Jun 12, 2010 8:21 pm    Post subject: Marquee 8500-Boards to disconnect for initial setup
Hey Guys,
I can't find a thread I thought I bookmarked a while back that lists the boards to disconnect when doing a 'from scratch' setup. Pi$$es me off as I knew I'd need it when I got to the point I'm at in my HT makeover.
Anybody have links? The Search function here is, well, less than useful and Google isn't being very friendly for me either. Laughing
Thanks!
Greg
Posted: Sat Jun 12, 2010 8:24 pm    Post subject:
Only disconnect the Astig when doing the CPC magnets. Thats about it.
JustGreg
Posted: Sat Jun 12, 2010 8:25 pm    Post subject:
Thanks Nash! OK...I'm off to get this done! WOOOHOOOOOO! Mr. Green
Greg
Posted: Sun Jun 13, 2010 12:06 am    Post subject:
Pull the CMM board out. Disconnect the focus yokes, too, to check basic magnetic focus. It should be pretty close, at least in the center of the image. If the yokes are at the perfect magnetic strength, the central focus will be excellent. Also the image should not shift much
if at all when you plug the focus yokes back in.
Your basic focus values in the center of the picture should be at 50 +/- 10 points. 20 at the most. If it's outside those limits, you should
be looking for another set of focus yokes or get the original set recalibrated. Someone here can help get that done but I'm not going
to volunteer his services for him.
CJ
Posted: Sun Jun 13, 2010 12:14 am    Post subject:
Cj's right on the focus coil if you plan to move it up and down the neck to find the sweet spot. I left it out since your having so much trouble right not and the electronic controls will make up for a slightly imperfect focus coil placement.
JustGreg
Posted: Sun Jun 13, 2010 12:26 am    Post subject:
CMM has been out since I first got the set.
I'll disconnect the focus yokes later...IF THE FRIGGING THING WILL STAY RUNNING THAT IS!!! (not yelling at you guys...just PO'd at the pj) (See other thread).
Greg
Zolzar
Posted: Sun Jun 13, 2010 12:55 pm    Post subject:
I just happened to do a full initialization and setup yesterday to squeeze that last ounce of performance when I noticed this morning Nash mention to disconnect the astig board. I didn't do this and I never have. I did zero out all zones of electronic astig to 50/50 before adjusting the CPC magnets. Is this reasonably acceptable? I managed to get the astig looking pretty darn sweet not to mention the end result is visually stunning. I'm not going to go back and go over it anytime soon but I'm just curious for future reference.
John
