JustGreg
| Posted: Sat Jun 12, 2010 12:12 am Post subject: Marquee 8500 No Joy after retubing |
This is a long one but I want to be throrough.
I replaced the red tube with a new one a month ago...set powered up fine.
Just replaced the G&B with almost new tubes and no go. The G&B came with all coils and mags in place so I used those.
The set powers up, the HDM relays do their thing but the last relay, which I assume is the call for HV, latches but no HV.
I've swapped out or checked:
CLM
Neck Boards
HV Splitter
FCM
Don't have a known working HDM spare
Checked all cable connections
Reseated the FCM and HDM multiple times
Reseated the HVPS and LVPS-I have spares but it isn't easy to drop the pj to change them. The pj face is upagainst an I beam.
I've checked the umbilicals several times but haven't replaced them. That's next.
Checked/reseated the wired remote, LVPS and HVPS connectors at the UMB and LMB.
Removed the connectors from SAB
Disconnected the FCM
I have NO spare heatsink boards to try
The heaters ramp up in amplitude when the set is on if that means anything and P14 was set with connector disconnected before the red tube was installed. (6.35v) I haven't checked the voltage with P14 connected and set on however.
There are a couple things to note that happened thoughout the retube process:
1) After installing the red tube I found I had to reseat the HDM several times before HV would energize. The set powered up fine every time after that.
2) The new blue Stig cable white wire was ripped out of the metal connector at the board plug. I didn't notice this until I was troubleshooting for no HV after the set had obviously been powered up once and the HDM reseated again.
3) When lowering the blue tube I learned the hard way the HDM and cage should be removed as the end that is secured to the rear heatsink; (which was being suspended in the open position) dropped. The only thing holding it up was the front cage screw but I caught the board (cables still connected) before it could slide too far out of the cage. No broken width slugs but I didn't meter test them.
The next thing while waiting for a reply is to swap out the PS's (then test), pull the red tube and closely check the UMB connectors (then test) and put in new NB umbilicals and test. The only other thing I can think of is to remove all the tubes and remove the LMB and check the solder joints for the HDM female connector. God only knows how many times the HDM has been slammed in and wiggled over the years prior to me owning the pj.
Any other ideas? Is it possible one of the formerly working (before shipping to me) tubes and/or yokes could prevent HV? I suppose I should add putting the old tubes back in to the list. *sigh* I'd appreciate any voltage test nuggest anyone might have also.
Thanks guys.
_________________ Greg
Sparky015
| Posted: Sat Jun 12, 2010 12:39 am Post subject: |
Greg, sorry to hear you still have no joy. So to replicate your situation, everything worked until yuou made the G & B tube change, then nothing, correct? The only other thing that happened was the #3 HDM incident. You touched nothing else?
#1 seems fishy. Could be mother board, could be HDM as well. You need an HDM to check. You can also do a continuity check of the motherboard HDM connector as well to verify good connector / solder joints. If you need the motherboard schematic, let me know, I believe I have it. I think it's also on Nash's mini website as well. I think that's where I got it in the first place.
#2, although disturbing that it's damaged, should not affect HV. ASTIG is not tied to that circuitry, only deflection, focus, tube ribbon cables, VIM and CLM.
#3 may tie to number 1, but if you caught it before the wires caught, I would think there was no harm, no foul here. I would think you would see an H-fail light as well.
Given that you don't have any diagnostic lights, it may be a PS, but sort of doubtful, as there is even a light for those. No diagnostic lights on the LVPS lit?
You could try hooking back up your old tubes to see if it is infact a bad tube. Not feeling it though. Meter the deflection and focus yokes. THe resistance values should be similar to your known good red, and even your old B and G tubes. If one of them is open, it will also not allow HV to come on. That will vet out the magnetics, at least the main magnetics needed for HV.
Check the motherboard connector for the HDM. Are the contacts clean? Having to reseat it a few times to get it to go seems to point to dirty contacts.
Let me know what you find. I hope you find those tubes are OK. I also hope you don't have to drop the pj.
_________________ ~Paul
Sparky015
| Posted: Sat Jun 12, 2010 12:49 am Post subject: |
out if curiousity, if you disconnect one of the the horizontal cables, do you get a H-fail diagnotic light then, or still nothing and no HV?
| Posted: Sat Jun 12, 2010 1:22 am Post subject: |
Alot to read and maybe I missed it but did you recheck for a bent pin on any of the tubes?
JustGreg
| Posted: Sat Jun 12, 2010 2:15 am Post subject: |
| macgyver655 wrote: | | Alot to read and maybe I missed it but did you recheck for a bent pin on any of the tubes? |
Sorry for the novel Mac...like I said I wanted to be throrough in order to get peple thinking outside what I'd already done. And yup...I checked all cards, cables, tubes, etc for a bent pin. I'm good for missing things like that so that's where I went first...the easy fix!
Paul, I haven't pulled an HDM cable yet to check for H Fail. I'm still scouring the schematics and putting together a list of things I can remove or disconnect without spot burning the tubes. I'm still not sure what I can get away with. I had all the things listed years ago but can't find it. I probably put it 'somewhere it wouldn't get lost'.
The SM has a number of boards that can be 'offloaded' (WTF...just say removed or decabled for cripe sakes!). They are:
HDM, FCM, CVA, VDM, SAB, and VNB's. OK cool but that doesn't leave much does it?! What must the set absolutely have installed?(notice I said installed not just decabled)
No error lights whatsoever. The only thing I noticed that I had never seen before was when powering it up the first time after installing the B&G with the wireless remote I noticed the light on the wired remote flickered for a good 3 seconds. Probably normal as I never use that remote.
Can I remove all cables from one tube at a time to test and not hurt anything? IS it OK to disconnect HV to each tube one at a time and test? GAAAAAAAAAAHHHHHHHHHHHHHHH!!!
JustGreg
| Posted: Sat Jun 12, 2010 2:54 am Post subject: |
OK...I got it. A wire at P5 wasn't secured in the connector. The little metal tab that keeps the crimped on connector from backing out was flattened. Put a little angle action on it...plugged it in and JOY JOY JOY!!!
I've never had new tubes before so not sure what the output is supposed to be with factory G2 but the blue at 60 isn't as bright as the R&G. Is that normal for blue? Mechanical focus seems kinda crumby too; at least on green. But it just got a full initialization so I'll know better in a couple hours if something's amis with the FCM. WOOHOOO!
Thanks for replies guys!
| Posted: Sat Jun 12, 2010 3:01 am Post subject: |
Ok, you didn't even really read the post and you figured out what was wrong. How in the frick do you do it?
dvh99
| Posted: Sat Jun 12, 2010 3:06 am Post subject: |
1 advice do not glue the focus yoke yet (or don`t at all).
do this after astig has been done properly.
and you might want to check convergence timings.
cmjohnson started a thread on it a while ago.
and yes blue light output is much less.
good thing you got it working.
CRT_Ben
Joined: 28 Aug 2006 Posts: 1684 Location: Northern Virginia
| Posted: Sat Jun 12, 2010 3:27 am Post subject: |
| JustGreg wrote: | OK...I got it. A wire at P5 wasn't secured in the connector. The little metal tab that keeps the crimped on connector from backing out was flattened. Put a little angle action on it...plugged it in and JOY JOY JOY!!!
Thanks for replies guys!  |
Hey Greg,
I've been following but not posting because I didn't have any bright ideas as to the problem - I'm glad you got it working! Here's to hoping your first setup goes smoothly
Ben
| Posted: Sat Jun 12, 2010 3:45 am Post subject: |
Glad you got it working. I have computer problems at work all day so i was doing that and did not look at CurtPalme.com once the whole time !!
I think I screwed myself with my Back of House computer. might have to do a clean install if i can get out of the repair mode it keeps looping too. but thats another story.
At least someone got something working right tonight!
Now get on with the set up!!!
JustGreg
| Posted: Sat Jun 12, 2010 7:26 am Post subject: |
Thanks man! So far the few minutes of pattern I had streamed from the PS3 were rock solid with no jitters.
I didn't do anything to the pj after getting it running except for maxing the rasters. Then on to finding the right spot for the screen and getting it hung.
Gotta pull the red lens again tho...I didn't get all the Sharpie marker center dot off. I'm moving into the final stages but MAN I hate doing magnetics with a frigged up back like mine. I'll get it done and be bedridden for a couple days but it will be worth it!
And wait...whu?....YOU are getting your butt kicked by something electronic??? No way. You just need to step away from it for a while and it will come to you....probably in your sleep.
BTW Paul, the blue output is fine at factory recommended settings. I just had to turn the lights down and it looks fine. Gotta get a colorimeter and do grayscale to be sure tho. (Nash?...hint hint)
JustGreg
| Posted: Sat Jun 12, 2010 7:29 am Post subject: |
| CRT_Ben wrote: | | JustGreg wrote: | OK...I got it. A wire at P5 wasn't secured in the connector. The little metal tab that keeps the crimped on connector from backing out was flattened. Put a little angle action on it...plugged it in and JOY JOY JOY!!!
Hey Greg,
Ben |
Thanks Ben and dvh! It isn't my first but I'm treating it like it is because I made so many newb mistakes the first couple times around. I'm commited (or should be) to getting it as close to non ISF perfect as I can this go 'round. No more weekly convergence drift corrections and I WILL nail grayscale instead of winging it.
Sparky015
| Posted: Sat Jun 12, 2010 12:20 pm Post subject: |
Greg,
Glad to hear you figured it out. I'm disapointed so many issues with those connectors. I wonder what happened? Did they get stuck in the foam? I'm really sorry about that. I am glad that your back up again. Hopefully you won't have to do too much to the magnetics since they were done by Electrohome. Hopefully just ASTIG.
Now heres hoping I fix my arc issue and repair three boards this weekend!
| Posted: Sat Jun 12, 2010 1:31 pm Post subject: |
| Spanky Ham wrote: | | macgyver655 wrote: | | Alot to read and maybe I missed it but did you recheck for a bent pin on any of the tubes? |
Ok, you didn't even really read the post and you figured out what was wrong. How in the frick do you do it?  |
I dont remember off hand where P5 is Spank but I dont think its for the tube pins, lol. But thanks for the confidence.
JustGreg
| Posted: Sat Jun 12, 2010 8:11 pm Post subject: |
| Sparky015 wrote: | Greg,
Now heres hoping I fix my arc issue and repair three boards this weekend!  |
Hey don't sweat it Paul. The connector that was the issue had nothing to do with a tube. It was at the LVPS harness connectorat the Upper Mobo,at the red tube. The white wire on the SAB plug on the blue I got from you is a non issue as the pj will still run with one of those plugs off. It was just a freak thing that tripped me up.
As they sit now without touching the mags yet, the images need to be centered on the face. No biggie as long as VDC didn't glue the bahjeezus out of everything...I haven't checked yet. It's all the overhead work I dread in this phase...BUT...I'd rather work overhead than tackle Scheimphlug any day!
Good luck with your HV issues man. Let me know if you need another tube lead with a boot on it. I have nothing BUT low emission (but good phosphor) tubes laying about now. 2 of each color to be exact.
| Posted: Sat Jun 12, 2010 9:55 pm Post subject: |
So sell them on ebay "as is" with no warranty expressed or implied. "I have no way to test these." But be sure to tell us your ebay handle so that we don't buy them!
Actually...how low IS their emission? Can they be driven to a usable brightness level? They may still be good enough for me to use them
in a test rig...if I can ever get someone to sell me a Marquee chassis for a fair price, that is!
CJ
