g70 Error 26
matteomo
Posted: Mon May 31, 2010 1:07 pm    Post subject: g70 Error 26
My Sony G70 had a failure on E board (error 35) and so I change it with another board. The Error 35 is now ok but there's a new error: 26 LENS - A lens is removed. Can someone help me?
Posted: Mon May 31, 2010 1:22 pm    Post subject:
Ahh, the infamous lens error. Doc can tell you about that experience, lol.
If you didnt remove a lens or one of the lens wires then you may have a failure one the lens control board or voltage to that board. The bigger problem is the power to that board travels through many boards to get there so you may just have a bad connection somewhere.
Did you remove any lenses or lens wires?
matteomo
Posted: Mon May 31, 2010 1:37 pm    Post subject:
No. I've not remove any lens. Sad
I've change the E board with another one coming from another G70. Maybe this is the problem.
matteomo
Posted: Mon May 31, 2010 1:40 pm    Post subject:
Wich is the "lens control board" on G70
Posted: Mon May 31, 2010 1:59 pm    Post subject:
I've seen all sorts of strange error codes when swapping boards on G70s. I can repair the original board if you want.. Check the 3 pin connector on the PA board coming from the lens wires. Maybe it came loose?
Posted: Mon May 31, 2010 2:16 pm    Post subject:
CN407
matteomo
Posted: Wed Jun 02, 2010 11:15 am    Post subject:
All OK. The lens cable wasn't connected... Wink
