Zenith 900 Sony BR & HDfury3 - i know for you guys
jeffslife
Posted: Sun May 30, 2010 3:11 pm    Post subject: Zenith 900 Sony BR & HDfury3 - i know for you guys
this is probably a dumb question but i am new to this. i have small amounts of blue hotspots. any help? jeffslife@yahoo.com
Tittle updated ~MOD
Posted: Sun May 30, 2010 3:13 pm    Post subject:
What projector? What source?
jkruger
Posted: Sun May 30, 2010 3:14 pm    Post subject:
Hotspots or sparklies?
jeffslife
Posted: Sun May 30, 2010 3:15 pm    Post subject:
zenith 900 , sony blue ray rgb fury 3 inputs
We are ALL job creators !
Posted: Sun May 30, 2010 3:19 pm    Post subject:
How long is your HDMI cable?
jeffslife
Posted: Sun May 30, 2010 3:23 pm    Post subject:
hotspots, random places, 30 ft attached to an hd fury 3 next to the projector. by the way great charger 383?
Posted: Sun May 30, 2010 3:26 pm    Post subject:
When you say "hot spots" what do you mean exactly spark? Are you getting sparklies? Do you have a shorter cable to try? What resolution are you running? Can you try a lower resolution and see if the hot spots go away?
Not sure what motor that Charger has in it. I'ts not mine.
jkruger
Posted: Sun May 30, 2010 3:32 pm    Post subject:
Try a shorter HDMI cable. 30 ft can give you sparklies.
jeffslife
i get small areas along edges of things inside the picture of blue where no blue should be not sparklie though.
cable length im stuck with. running 720 i res. if i go lower thers no point in having it
jkruger
Posted: Sun May 30, 2010 3:34 pm    Post subject:
Sounds like a convergence issue.
Posted: Sun May 30, 2010 3:37 pm    Post subject:
Ok I've seen what you are describing but on a Sony D50. Let's ask Curt on this one. Maybe smearing?
Do you have a 6 foot HDMI cable you can test with? I understand you not wanting to run 480p but try it as a test, though I think this may be a projector issue.
EDIT: Yes what J said too. When was the last time you did a convergence?
Posted: Sun May 30, 2010 4:41 pm    Post subject:
Can you post a picture of what you're seeing?
Thanks!
jeffslife
Posted: Sun May 30, 2010 5:36 pm    Post subject:
jeffslife
Posted: Sun May 30, 2010 5:47 pm    Post subject:
dont have a shorter cable . the convergence isnt perfect but its as good as i can get it . it never did it on s video still doesnt. does it make a difference if the fury 3 is close to the blue ray or is it better up close to the projector which is where it is now.
Posted: Sun May 30, 2010 5:48 pm    Post subject:
Get a short cable and put the BR player right under the projector. I'm not sure whether you have set, cable, source or Fury issues right now.
jeffslife
Posted: Sun May 30, 2010 5:51 pm    Post subject:
ok gotta run to town its a little drive . will try then get back to you . thanks
Posted: Sun May 30, 2010 5:53 pm    Post subject:
I am not familiar with the Zenith 900. But it sounds like you may have lost Blue focus. Can you bring up an internal Grid pattern of each color individually and see if the blue grid lines are much wider than the red and green.
jeffslife
Posted: Sun May 30, 2010 7:58 pm    Post subject:
found the problem blue lens screwed up will get back to you all later thanks for the help jeff
