napos
Joined: 21 Oct 2006 Posts: 164 Location: Athens, Greece
| Posted: Fri May 28, 2010 5:18 am Post subject: Problem with Marquee 8500: Image shaking horizontally. |
I need your help on this one. The image seems to "shake" horizontally at random occasions. It lasts for a few seconds. These last few days the temperature has really gone high in Athens, and it is also very humid. Could that be a factor on any of the boards? Other than that, convergence is not affected, and focus is better than ever, after my recent installation, about a month ago. Before that, the projector had not been used for about a year. Any ideas on what I could try?
I also have a Marquee 9500Ultra, which I am not using due to some problem with fungus on the red tube and an issue with the green neck board. Could I use any of the boards of the 9500 if needed?
Looking forward to hearing from you, since there are no CRT technicians in Greece.
Nicholas
_________________ Marquee 9500LC Ultra with MP mods, Moome HDMI 1.3 card, Lumagen Radiance XS, Oppo 83 BluRay, Toshiba XE-1 HD-DVD, HTPC with Media Player Classic.
CZ Eddie
| Posted: Fri May 28, 2010 5:49 am Post subject: |
I would start by swapping the Ultra's CLM into the Marquee. You won't be able to use all the options, if your other Marquee isn't an Ultra. But the CLM should still perform the basic functions I think.
From there, I would try the HDM. As that is where the width pots are. These two options are super easy to swap out. Like a minute for the CLM and five minutes for the HDM (removing covers).
And then try the convergence boards on the heatsink, which are more of a time consuming swap. But still easy.
I have a feeling it'll be the CLM though. If it is, then you could clean it and reseat the chips, or press down really hard on them.
_________________ Back after a digital sabatical.
| Posted: Fri May 28, 2010 10:26 am Post subject: |
Before you start swapping boards around, try wiggling the BNC sync connectors on the back of the projector and the source. You might just have a bad sync connection.
_________________ Chip
| Posted: Fri May 28, 2010 1:54 pm Post subject: |
Hi Nikos, one question. What resolution are you using? If 1080p you have to make sure the sync timing is larger than 1us.
But Eddie might be right with the clm. Since the humidity and heat build up in Athens the chips might be oxidizing a bit more.
First chip to check and clean is U7 on the DPB.
Also Chips suggestion is a sound one as well.
Sparky015
| Posted: Fri May 28, 2010 10:10 pm Post subject: |
clean all of the contacts with deOxit, especially the DPB on the CLM. Both my 8000 and 8500 had this problem. The other thing that added to it on my 8000 was a bad C50 on the HDM. Recapping it and cleaning the contacts did the trick. C50 will depend on what resolutions the pj has seen over the years and at how many hours.
_________________ ~Paul
JustGreg
| Posted: Sat May 29, 2010 2:49 am Post subject: Re: Problem with Marquee 8500: Image shaking horizontally. |
| napos wrote: |
Nicholas |
And there ya go Nash!!! It's all wide open for you to set up a business.
_________________ Greg
dvh99
| Posted: Sat May 29, 2010 2:55 am Post subject: |
www.nashpalme.gr
napos
| Posted: Mon May 31, 2010 1:02 pm Post subject: |
Thank you all for the quick reply. Since I am in Greece, I don't think I will find the brand names you mentioned regarding the cleaning products. What are the ingredients I should look for? Also, what method should I use for the cleaning? I have never done anything like this before. Is there a section in the main site that describes this procedure?
I have noticed that this problem is more apparent if I do any convergence or focus electronic adjustments. I also played around with the timing settings on my Lumagen HDP and that seemed to help. When I switch to another resolution with a different scan rate the problem dissipates.
| Posted: Mon May 31, 2010 3:39 pm Post subject: |
The last time I had a horizontal stability issue on my 9500LC, I fixed it by pulling the HDM and reseating the daughter board and all the
chips on it, and all chips on the HDM itself which were socketed. No further problem.
CJ
JustGreg
| Posted: Mon May 31, 2010 6:17 pm Post subject: |
| cmjohnson wrote: | The last time I had a horizontal stability issue on my 9500LC, I fixed it by pulling the HDM and reseating the daughter board and all the
CJ |
Not to segue` off too much but those two boards (FCM and HDM) pi$$ me off to no end what with their almost non-existent ability to defy gravity! I've tethered the cages to the board and today I'm going to drill through the dimple on the latch end of the cage and install a stainless self tapper into each one. Yesterday the damn FCM dropped right out of the bugger while working on it!
Good thing I was right there to get freeking zapped by the hanging HV splitter or else the FCM would have dropped until the cables were the only thing stopping it from hitting the floor. POS design!
napos
| Posted: Tue Jun 01, 2010 11:51 am Post subject: |
I removed and reseated the HDM and it appears that everything is OK. The image appears to be more stable in general, also in terms of motion handling. I also got the impression that the image was a little bit brigher and sharper, with better focus.
| Posted: Tue Jun 01, 2010 12:39 pm Post subject: |
| napos wrote: | | I removed and reseated the HDM and it appears that everything is OK. The image appears to be more stable in general, also in terms of motion handling. I also go the impression that the image was a little bit brigher and sharper, with better focus. |
Great!! What you should do is try to add a little more foam inside the cover for the HDM and FCM, maybe a 5mm strip.
| Posted: Tue Jun 01, 2010 6:36 pm Post subject: |
Oh, I spoke too soon.
I have a Moome DVI card in my Marquee. It SOMETIMES works at 1080p but not always. But I can't say if that issue is with the card
or the player or the length of cable gong to my Blu-Ray player. (I am using an HDMI cable with an HDMI to DVI adapter at the Moome card.)
In the past, at 1080p, after the PJ had been running for a while I'd get a rapid horizontal vibration in the picture, strongest at
the top of the picture and weakest at the bottom.
I haven't seen it in months but last night it came back near the end of a movie. I can temporarily get rid of it by switching to a lower
resolution for a few minutes and then going back to 1080p, but eventually the shake will always return.
I don't think that this is going to be a bad connection problem. My personal guess is that I have an electrolytic cap on the HDM that's
starting to give out. Its ripple current increases as it gets hot in use. Just my guess.
CJ
