Need help with a NEC XG 75
kilgore trout
Posted: Wed May 26, 2010 12:19 am    Post subject: Need help with a NEC XG 75
My main problem is controlling the projector. We found this projector at school, and I was asked to get it up and running. I don't have a RC-6321 remote, so I'm going to have to use the PC control interface to configure it.
Now I have a couple questions about exactly how to use it. The PJ connects to the PC through the serial port, so I'm going to have to find a cable that goes from 9F to 15M. This is where the problem starts. Do I have to make such a cable, or would a serial cable with a 15 pin converter at the end suffice? Or could I buy it somewhere?
Thanks a bunch to anyone that can help me.
dvh99
Posted: Wed May 26, 2010 12:55 am    Post subject:
there are usb to rs232 cables available i dont see the problem.
dvh99
Posted: Wed May 26, 2010 12:57 am    Post subject:
btw i love the dexter series.
Posted: Wed May 26, 2010 3:37 am    Post subject:
I think you need the cable, or I have one spare remote for $125 incl shipping.
DO NOT use a USB to serial converter, almost none of them work properly. Get a laptop or a desktop with a 9 pin output and whip the cable together. THe manuals on the main site should have the pinouts, although I've never built or used one before via PC.
Posted: Wed May 26, 2010 3:42 am    Post subject:
I have built the cable and used the software for the PG model. For the XG model you have to check your serial number to see if the software is compatible.
Of course I dont know what an XG75 is..... I never heard of one...... Laughing
kilgore trout
Posted: Wed May 26, 2010 5:03 pm    Post subject:
Would I be able to use a serial cable with a 15 pin converter on the end of it? And I think the serial number is... missing on the PJ. It should be on the label on the bottom right corner of the back, correct?
Posted: Wed May 26, 2010 5:14 pm    Post subject:
I'm not sure if you mistyped and meant 15 pin connector, but converter...... probably not.... but I cant say for sure. I just used an old printer cable and cut one end off and wired up the other connector. Edit, no wait. Printer cable is wrong I think. I think I just bought a 15 pin connector from Radio Shack or something.
I still dont know what an XG75 is. Can you fill me in..... Laughing
kilgore trout
Posted: Wed May 26, 2010 5:24 pm    Post subject:
I did mean converter, but I figured it wouldn't work. And an XG75 is a model for for a NEC projector.
http://www.curtpalme.com/CRTforSale_HighPerformance.shtm
Posted: Wed May 26, 2010 5:52 pm    Post subject:
LOL. Now there's something Curt should correct. There is no such thing as an XG75. I have been kidding with you.
There is an XG750 and an XG751 which many use the XG75 reference to, but these 2 machines are completely different. So the correct model number MUST be used when seeking information on either one.
Sooooooooo.... do you have an XG750 or an XG751? Very Happy
dvh99
Posted: Wed May 26, 2010 8:46 pm    Post subject:
i used a usb to rs232 cable on a satdecoder and it worked fine.
it came with a little disk with the driver on it, i dont see why it wouldnt work on a pj.
besides, its cheap and easy so why dont try it.
kilgore trout
Posted: Wed May 26, 2010 9:44 pm    Post subject:
It's a XG 750, sorry for not specifying
ccaddaddy
Posted: Sun May 30, 2010 2:26 am    Post subject:
i'm having the predicament. my laptop only has usb and vga, no serial port. so i guess i'm up s**t creek without a paddle then?
"To forgive is divine but never pay full price for late pizza." Michaelangelo
jarseneau
Posted: Mon May 31, 2010 4:54 am    Post subject:
If your laptop has a docking station, most of the time it will have a serial port. I believe your only other option is the USB to serial converter but Curt is right in that they don't all work the same.
Jerry
kilgore trout
Posted: Fri Jun 04, 2010 5:02 pm    Post subject:
bump
Posted: Fri Jun 04, 2010 6:49 pm    Post subject:
Not sure what the bump is for. I thought your questions were answered. Smile
jarseneau
Posted: Wed Jun 09, 2010 7:04 pm    Post subject:
In case you are still looking for this PC to NEC cable, I believe the only way is to make one yourself. Probably the easiest way would be to buy connectors like these at this link and follow the pinout shown in the link in Curt's site. For the wire you can use a length of Ethernet cable commonly sold at most home improvement stores. Just be sure you get the correct gender for each plug. The PC end (9 pin) will be female and I think the 15pin end is male (plugs into the 15 pin REMOTE connector on the XG)
Jerry
ccaddaddy
Posted: Fri Jun 11, 2010 2:46 am    Post subject:
has anyone ever used this cable before? i just finished making one and tried to use it. anyone ever had any problems? didnt the xg have a camera that connected to the front of it to help with the convergence, if so where and how much r they?
ccaddaddy
Posted: Fri Jun 11, 2010 2:47 am    Post subject:
Blockbullie
Posted: Tue Jul 06, 2010 12:54 am    Post subject:
I tryed to make a cable and could not get It to communicate with a computer . after a couple of days of pulling my hair out I gave up. Mine was a xg 751 , I m thinking Its a meth. I wanted to contol mine by a computer ,to converge mine
Rich mans taste with a poor mans wallet
