Gerbrand
| Posted: Mon May 24, 2010 6:26 pm Post subject: P19LUGs in a 1996 BG1209s: a question about Scheimpflug |
All,
I recently bought a set of new P19LUGs from Terry and today I finally found time to start installing them in my 1996 BG1209s. This model does not have adjustable Scheimpflug. Instead it is fixed for a screen width of about 2.40 m.
When I removed the tube cover, I found a sticker on my original tubes saying "Special Scheimpflug corrected CRTs". So I suppose this means that something special has been done to these tubes to enable the Scheimpflug correction.
Now I have the following question: if I mount my new LUGs in this set, will I loose the Scheimpflug correction?
I have included a picture of the red tube + LC chamber below.
Thanks for your help,
Gerbrand
| Description: |
| Filesize: |
139.85 KB |
| Viewed: |
9858 Time(s) |
_________________ BG1209s (color filtered,new LUGs!), 13000h
Bat cave
zGman
| Posted: Mon May 24, 2010 8:11 pm Post subject: |
Before you remove the tubes from the housings - measure with c-element removed
the distance from the front of the housing to each tube corner. this offset will be the
flapping adjustment which will be optimized for a particular throw distance, possibly
listed on the PJ somewhere. Possibly you could make a jig using the old tube/housing
so that you can glue the new ones in at the same orientation.
G
| Posted: Tue May 25, 2010 2:20 am Post subject: |
It's just added spacers isn't it?
zGman
| Posted: Tue May 25, 2010 2:33 am Post subject: |
I don't know Mark - I have a similar housing here and there is no internal support for the tube -
just dug it out and had a look again today - really odd. I know some one in europe ( Ile? ) did
a 8" tube in 9" similar housing conversion and used the Barco program to calculate the flapping
corrections and made spacers (i think - it was a while back)
My concern for this setup is that he won't know if there are internal spacers until it's too late....
Seems best to take measurements and/or make a jig before cutting out the tubes.
And of course they will all be different.
G
Gerbrand
| Posted: Tue May 25, 2010 6:00 am Post subject: |
Thanks for your help so far. Hopefully Ile (?) chimes in, if he was the one who did this.
I am also concerned about the required accuracy here. I did some rough calculations at it seems as the required accuracy is of the order of 0.05 - 0.1 mm (1 or 2 mil for the Americans). This is not something you can do easily with a simple jig, but requires a machine shop.
I may be wrong, so I will spend some more time looking into this.
Gerbrand
Bat cave
Ile
| Posted: Tue May 25, 2010 7:31 am Post subject: |
| Mark_A_W wrote: | | It's just added spacers isn't it? |
No, hardware is glued unevenly to tube in these Barco constant LC hardware tubes.
Gerbrand
0,1 mm accuracy is more than enough.
Actually Barco corrected only vertical Scheimpflug, so in some cases horizontal Scheimpflug would be over 0,5 mm off. I corrected each corner.
You can calculate required corrections with lens software and check needed shims from text sheet. I made small 3x3 mm plastic shims to each corner of tube and glued those first to tube with rtv. Just make sure to check tube orientation (hv cable) before glueing shims. Then I just glued tubes to hardware normally, pressed corners against shims...
Here is my old thread about this.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=6463.html
Then you can made fine tuning by adding washers between lens and c-element. I didn't have to, glued corrections was spot on in my BG1200 and BG808s LC project.
Gerbrand
| Posted: Tue May 25, 2010 10:51 am Post subject: |
That is encouraging! I will have a look at your thread.
On the sticker on the tube it mentions alpha=10.5 degrees, which of course is the vertical Scheimpflug. It also mentions TCL=408 cm. Any idea what the TCL stands for?
Cheers,
Gerbrand
Bat cave
Ile
| Posted: Tue May 25, 2010 11:15 am Post subject: |
| Gerbrand wrote: | That is encouraging! I will have a look at your thread.
Cheers,
Gerbrand | No, alpha is projection angle and both Scheimpflugs for it depends about projection distance.
I guess TCL is distance between tubes face and screen, because it's 10 cm higher than projection distance from front support beam. You don't have to know what it's, if you use lens program...
What kind is your setup?
Ceiling/table?
Projection angle? (is projector bottom tilted or level)
Screen ratio and width?
This picture tels how I made calculations.
http://www.dvdplaza.fi/forums/attachment.php?attachmentid=3801&d=1095853469
Gerbrand
| Posted: Tue May 25, 2010 10:07 pm Post subject: |
This is the the output of LENS for my set-up. As you can see the Scheimpflug for my tubes is actually not quite correct for the screen width I use.
After reading your thread about "poor man's lens flapping" I had one question: what reference do you use for the plastic distance holders. One side it is the tube face, but on the other side ? Is it something that holds the C-element or the C-element itself?
Gerbrand
| Description: |
| Filesize: |
102.23 KB |
| Viewed: |
9690 Time(s) |
Bat cave
zGman
| Posted: Wed May 26, 2010 4:03 am Post subject: |
The housing I have here is just a cast aluminum chamber with no provision
for spacers....I am not going to post pics, but Ile may have some. I have no idea how
Barco put the things together but there must have been a production jig to set the
spacing from c-element to tube face. Whatever you do, I would recomend getting some precision
calipers and measuring the distance to the tube face before cutting out the old tubes,
so that you have some reference. If you were local I would volunteer to help with
measuring and machinework just for fun...maybe you can find a knowledgeable
local enthusiast and /or machinist? Best of luck with the project.
G
| Posted: Wed May 26, 2010 4:40 am Post subject: |
| Ile wrote: | | Mark_A_W wrote: | | It's just added spacers isn't it? |
That's what I meant.
I thought there were bits of plastic (or something) embedded in the silicone between the housing and the tube.
Is that it?
zGman
| Posted: Wed May 26, 2010 5:21 am Post subject: |
Hi Mark - From what I have here, the tube is just glued on the sides to the housing - no spacers
of any sort - "willy-nilly" you might say. Hence my conclusion there must be a production jig.
Later model 1209S housings use plastic buttons to set the spacing, but that is not the case for
these early models - in engineering speak the early models are a "Kluge" - similar in concept
to the oil spill technology ruining our gulf coast - skip some steps and hope for the best...
just not so funny anymore.....sigh....!
G
| Posted: Wed May 26, 2010 5:37 am Post subject: |
LOL I think you mean "kludge" Galen
But I understand what you mean.
Ile
| Posted: Wed May 26, 2010 12:09 pm Post subject: |
| Gerbrand wrote: | After reading your thread about "poor man's lens flapping" I had one question: what reference do you use for the plastic distance holders. One side it is the tube face, but on the other side ? Is it something that holds the C-element or the C-element itself?
Gerbrand | C-element housing have machined plane for tubes face plate, that plane is at zero angle according to c-elements back plane. So when you first glue plastic shims to tubes corners those will match to that machined plane when you are gluing tubes to housings.
After glueing I also measured dimension from each corner (c-element plane) to tubes face plate, just to make sure that each corner was pressed agains housing. I also measured same dimensions before tube conversion for reference.
Here's few shot of my 808s lc conversion project, shims can be seen in third picture. Aluminium adapters was used only because 8" tubes was too small for 9" housings.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=9961.html
Ile
| Posted: Wed May 26, 2010 12:27 pm Post subject: |
Here's shims for 235cm projection distance and projector not tilted. Used straight mm values from lens program.
Added 0,5mm to all corners, so now also zero corners have 0,5mm blade gap. It's easier to cut tubes out when needed to replace.
Gerbrand
| Posted: Wed May 26, 2010 2:30 pm Post subject: |
Thanks Ile for all the helpful tips and images. It really seems "doable" to me now. One more question, though: how did you manage to cut the plastic shims to the required precision?
And why not use metal shims? I know you can buy metal strips with well defined thicknesses (e.g. 0.1 mm). You could use a stack of those.
Gerbrand
Bat cave
Ile
| Posted: Thu May 27, 2010 7:03 am Post subject: |
| Gerbrand wrote: | One more question, though: how did you manage to cut the plastic shims to the required precision?
Gerbrand | I think I had 1 and 3mm thick plastic strips where I started and grinded most of material with angle grinder. Then finished to needed thickness over sandpaper disk glued to work table. It won't take long, because peaces are small and plastic is easy to grind.
One peace solution is better than stack of shims, because those need to be glued to tube or hardware.
Gerbrand
| Posted: Tue Jun 08, 2010 7:39 am Post subject: |
Hello,
Yesterday I had a chance to take the blue tube out of the projector. When I posted a photograph of it (below) on the Dutch htforum, it was pointed out to me that I actually have LC chambers of a newer type than Ile. Mine are made out of cast aluminium and apparently do not have a flat surface at the back, that can be used to glue the tubes against.
Basically it looks like that trick with plastic spacers might not work.
The only reference plane I can really trust, it seems, is the surface that the C-elements are bolted onto. So I think I should go for the following option:
First make an Al plate that can be bolted onto the chamber instead of the C-element. In this plate make four threaded holes, that can be used for reference bolts. Basically I screw those bolts in until they hit the surface of the tube. I can then use the bolts as a reference for glueing.
Does this sound like a good idea to you or are there better options?
Regards,
Gerbrand
| Description: |
| Filesize: |
145.69 KB |
| Viewed: |
6588 Time(s) |
Bat cave
Ile
| Posted: Tue Jun 08, 2010 9:02 am Post subject: |
I guess there is machined plane against tube face plate, that is now under rtv.
Gerbrand
| Posted: Tue Jun 08, 2010 9:24 am Post subject: |
I would really like to be sure about that before I cut the tube out of its housing. Does anybody happen to have pictures of exactly this kind of housing without the tube? Or would I be able to see this when I take off the C-element?
Gerbrand
Bat cave
