Is Tube/HV Hardware on XG AC's the same as PGs?
Ben851
Posted: Mon May 24, 2010 4:53 pm    Post subject: Is Tube/HV Hardware on XG AC's the same as PGs?
Story: In taking the tube housing's off of my old XG tubes, I've managed to crack the glass on two, and I'm pretty sure 2/3 HV Boots are wrecked as well. The good news on the HV boots is that I learned my mistake - some of the mineral spirits got on the boots and ate them up. As for the glass, I tried one tube first and soaked it in gas - it came off no problem after 2 days, but I think my problem is that I switched to mineral spirits for the second 2 and I guess 2 days wasn't enough to dissolve the silicone.
Question: I have a 6pg parts machine in the basement - are the housings and HV boots the same as those on the XG? I'd check myself, but it's currently buried...
Ben
Posted: Tue May 25, 2010 12:58 am    Post subject:
Yes, you can use the PG stuff.
The length of the HV wires will be different, but that's not difficult to change.
Ben851
Posted: Tue May 25, 2010 1:43 am    Post subject:
Phew that's a relief... now this time to be patient...
Ben
