marquee hdmi 1.3vim cropped image
dvh99
Posted: Thu May 20, 2010 1:28 pm    Post subject: marquee hdmi 1.3vim cropped image
ok i really hope someone can help me cause this is driving me nuts.
when connecting my pc to the pj via dvi-hdmi --> moome i get a great picture if i stay below the 165mhx pixellock 1080p at 64hz or so.
when i set powerstrip to 1920*1080 72 hz the image crops. it starts to crop at 1920*1080 65hz.
is there anyone out there that uses a pc with powerstrip and feeds 1920*1080 72hz into his internal hdmi v1.3 moome without the image getting cropped?
the dvi-hdmi adapter i use is dual link 24 + 1 pins so that cant be the problem.
the hdmi cable is a 1.3version so that cant be the problem either.
i really love to use the digital out of my graphics card cause the image thru the moome card is much cleaner then the rgbhv (vga)image.
edit: i asked this question before and someone told me that i exceeded the max bandwidth of the moome card, 165mhz.
looking at the specs it says the new vim has doubled the bandwith so the 185mhz pixelclock i am running into the moome shouldn`t be a problem.
dennis
