BG1209s firmware - someone have it?
Decibel
Posted: Fri May 14, 2010 11:54 am    Post subject: BG1209s firmware - someone have it?
I need the firmware of the Barco Graphics 1209s.
Someone have it?
I can program eprom then I seek the file only, not eprom.
Domenico (Barco fan!)
studio
Posted: Mon May 17, 2010 6:09 pm    Post subject:
Did you ever find it?
studio
Posted: Mon May 17, 2010 6:37 pm    Post subject:
Why not just copy the firmware from an existing eprom ? Why do you need it and what version ?
Decibel
Posted: Mon May 17, 2010 6:43 pm    Post subject:
I have not found.
You have it?
Decibel
Posted: Mon May 17, 2010 6:50 pm    Post subject:
Correct but I haven't 1209s eprom for copy Very Happy
I need it because I've found in my town a 1609s and I would try to swap firmware.
Posted: Mon May 17, 2010 6:57 pm    Post subject:
I need it because I've found in my town a 1609s and I could try to swap firmware.
Not sure but I don't think that will work. What are you trying to achieve ?
Decibel
Posted: Mon May 17, 2010 8:16 pm    Post subject:
Tom.W wrote:
What are you trying to achieve?
I would like to know what are the differences between these models to modify the 1609s
The motherboard and HV section should be the same.
Posted: Tue May 18, 2010 2:22 am    Post subject:
You can download the 1609s manual here...
http://www.devicemanuals.com/company/Barco-manuals.html
As for converting the 1609s to a 1209s the firmware is not all that is required.
Never seen a 1609s service manual but if it has an Iris 3 then it most likely has the latest 1609s firmware.
The latest firmware for a 1209s is labeled V7.20 on the eprom located on the controller board and it converts an Iris 2 to an Iris 3.
