| Posted: Fri May 07, 2010 1:21 pm Post subject: VDC is now using Clinton tubes. Don't worry! |
It's not news to some of you that VDC is now using Clinton tubes in Marquees.
Well, I've seen these Clinton tubes, both naked and in operation, and let me assure you, if you end up in need of
new tubes for your Marquee and end up in a position where only Clinton tubes are available, you don't need to
worry about the quality of them. They are quality tubes, fully comparable in every respect to the Panasonic CRTs
that have been standard in Marquees and other brands of projectors for a long time now.
While it seems that Panasonic branded tubes have reached the end of production, Clinton tubes are just as good
and will be available for quite some time to come.
I'm sure Tse will back me up on this.
CJ
jradwanski
| Posted: Fri May 07, 2010 2:16 pm Post subject: |
yes but are they hi rez tubes like lugs or standard like the stock marquee tubes
| Posted: Fri May 07, 2010 8:30 pm Post subject: |
They're available in both LCP (standard) and LUG (high res) versions. They are very equivalent with the associated Panny tubes.
| Posted: Fri May 07, 2010 9:01 pm Post subject: |
Unfortunately, for tubes, sometimes their true quality is not known until some thousands of hours of use. Hopefully they will pass this test also and keep CRT alive.
| Posted: Fri May 07, 2010 9:42 pm Post subject: |
Geez Tom. You have the number.... call them up......
| Posted: Sat May 08, 2010 2:20 am Post subject: |
Not in the market...Plenty of new spares
| Posted: Sat May 08, 2010 9:13 am Post subject: |
Not in the market....new tubes installed....will cave into new technology by the time this set is used up....perhaps even sooner
I'm convinced that a "good enough" alternative (damn close now) for less than the price of three new tubes will be available before these tubes are used up.
_________________ Chip
| Posted: Sat May 08, 2010 3:45 pm Post subject: |
That's reality. I've seen the new VDC Marquee HD SSL6000, which is a 3 chip DLP with RGB LED lighting, at 1080p, and
there are very few flies on it. Its picture quality is excellent and the black level is more than acceptable. The Phlatlight LEDs
that drive it should pretty much guarantee that this will be a "set it and forget it" device until some component fails. I think that
the weak spots are cooling fan life and the limited service life of some capacitors. It's a 70,000 hour lifespan projector, at a
conservative guess. No lamps to replace. No CRTs to burn.
The end for CRTs is drawing ever nearer but we won't be lacking for high quality choices when it comes.
CJ
| Posted: Tue May 11, 2010 12:20 pm Post subject: |
I found out a little bit more. The Clinton tubes are made on Panasonic fixtures to Panasonic specs. VDC got the Panasonic production line and Clinton is the VDC subsidiary that installed it and set it up and has resumed production of Panasonic CRTs under their own name.
Aside from possible short-term issues with the Clinton personnel learning any of the hidden tricks and secrets that may be involved with the construction of Panasonic tubes, which I tend to think isn't going to be much of an issue as the people at Clinton are well experienced tube builders, these should be very much the same tubes that we've seen for many years bearing Panasonic labels.
Incidentally, VDC now offers CRT replacement and rebuilding for ALL brands of projectors. The'll replace your old tube in your existing housing with a brand new tube. Sony, Barco, AmPro, whatever...odds are they can handle it.
CJ
dvh99
| Posted: Tue May 11, 2010 12:45 pm Post subject: |
this is what i got from vdc a while back and says it all.
The difference between LCP and LUG CRTs; the type of CRT to use is depended on the application. In summary;
The LUG (or as we have dubbed SIM) is primary used with a higher resolution (~2500 lines) with a lower light output. Typically a total room blackout or immersive environment.
The LCP type CRT is best suited for a control room, class room, home theater or controlled room lighting environment using >2000 lines of resolution and a greater light output desired.
VDC Display Systems (VDCDS) offers several options for replacing CRTs.
Option 1; Purchase an all new CRT assembly either fully dressed (Magnetics and shielding) or undressed (No magnetics)
Option 2; New with Exchange. This option is the same as Option 1 but VDCDS will exchange your used CRT assembly (fully dressed) with an all new assembly
Option 3; Renew with Exchange. This option uses an all new CRT with reclaimed hardware and magnetic components.
Option 4; Repair or rebuilt option. This option installs a new CRT into your hardware and/or magnetic components.
All options carry a 1-year limited factory warranty.
All options are factory tested and in the case of the of fully dressed CRT assemblies; these are factory tested and pre-aligned.
VDCDS CRT Exchange/Renew Program
VDC Display Systems is pleased to announce that it has expanded its CRT services for its series of projectors which now includes; New, Exchange
w/New, Exchange w/Renew and CRT Repairs. Additional Discounts may apply. See CRT Illustration for additional information.
VDCDS P/N Description New Exchange w/New Exchange w/Renew Repair Price
prices for lcp tubes.
LIST PRICE
81733-04 CRT 9" Red w/Magnetics $3,380 $2,704 $2,197 $1,318
81733-05 CRT 9" Green w/Magnetics $3,380 $2,704 $2,197 $1,318
81733-06 CRT 9" Blue w/Magnetics $3,380 $2,704 $2,197 $1,318
Wednesday, February 24, 2010 VDCDS CRT Exchange/Renew Program Page 1 of 2
next are the prices for lugs.
LIST PRICE
03-000254-01P CRT 9" Red w/Magnetics $3,230 $2,584 $2,100 $1,250
03-000254-02P CRT 9" Green w/Magnetics $3,230 $2,584 $2,100 $1,250
03-000254-03P CRT 9" Blue w/Magnetics $3,230 $2,584 $2,100 $1,250
03-000254-05P CRT 9" Red w/Magnetics $3,130 $2,504 $2,035 $1,250
03-000254-06P CRT 9" Green w/Magnetics $3,130 $2,504 $2,035 $1,250
03-000254-07P CRT 9" Blue w/Magnetics $3,130 $2,504 $2,035 $1,250
03-000254-08P CRT 9" Green w/Magnetics Clear "C" Element $3,230 $2,584 $2,100 $1,250
03-000254-12P CRT 9" Red w/Magnetics 9500LC NO GLUE $3,230 $2,584 $2,100 $1,250
03-000254-13P CRT 9" Green w/Magnetics 9500LC NO GLUE $3,230 $2,584 $2,100 $1,250
03-000254-14P CRT 9" Blue w/Magnetics 9500LC NO GLUE $3,230 $2,584 $2,100 $1,250
03-000254-15P CRT 9" Red w/Magnetics 9500DM NO GLUE $3,480 $2,784 $2,263 $1,347
03-000254-16P CRT 9" Green w/Magnetics 9500DM NO GLUE $3,480 $2,784 $2,263 $1,347
03-000254-17P CRT 9" Blue w/Magnetics 9500DM NO GLUE $3,480 $2,784 $2,263 $1,347
03-007064-04P CRT 9" Green P43 w/Magnetics $4,910 $3,930 $3,195 $1,925
03-007064-05P CRT,9" Red w/o Magnetics $2,380 $1,905 $1,550 $930
03-007064-06P CRT,9" Green w/o Magnetics $2,380 $1,905 $1,550 $930
03-007064-07P CRT,9" Blue w/o Magnetics $2,380 $1,905 $1,550 $930
03-007064-08P 9" P43 Green CRT-w/o Magnetics $4,220 $3,375 $2,745 $1,650
03-007064-09P CRT,9" Green w/o Magnetics w/Clear C-Element $2,380 $1,905 $1,550 $930
