svlorelei30
| Posted: Wed May 05, 2010 10:29 pm Post subject: Convergence/adjustments of my Barco 808s |
I am seeking someone to come to my home and do a convergence and adjustments needed to my projector.
I had a issue with the input board that has been repaired and the projector rehung on it's ceiling mount. I purchased a HD Fury 3 and have installed that as well along with a new Onkyo Pre/Pro and Oppo blu ray player.
My problem is getting the image to fit the screen while still being able to use the subtitles for hearing impaired viewers. A friend tried to adjust the picture and now the corners are curved so the picture looks warped at the edges and the image is above the screen and nearly into the screen case. While the subtitles are still cut off on the bottom of the screen.
Also I am getting a haze of green on the lower right of the image and the lettering in the subtitles is not crisp/clear. So as you can tell I am not getting the ultimate picture I know the projector is capable of.
I am at wit's end in finding someone who can make the adjustments needed and come to my home to do them! The shop in Miami that repaired my projector's input board won't travel to my home as I am outside of their service area. The local AV stores are clueless when it comes to CRT projectors.
Can anyone help? I will offer to cover travel expenses ( within reason of course) and your time here adjusting the projector. I will even take you sailing if you have the time and enjoy such adventures too!
I am located in Fort Pierce, FL which is midway in the state on the Atlantic coast side. Help Please! Anyone ????
