fosgate500
| Posted: Wed Apr 28, 2010 7:27 am Post subject: marquee 9000 image ok but menu its reversed inverted words |
hi everybody, mods and users,
i got a marquee 9000,(its was a wish done)turn on ok , the picture and image its ok, i know i need to calibrate,etc
but the stranger for me its so the image its ok but the menu from remote control its inverted(like write ineverted)
i think its because are in rear proyector screen mode,maybe i need to turn to front proyector mode,
but the only problem its the menu, (like read or write in reversed mode)
its posible to fix this without mode inside, only with remote or a some button,
any help or pics,ink to fix it its a welcome and thanks for read mi post
respectfully fosgate500
David_Web
| Posted: Wed Apr 28, 2010 8:44 am Post subject: |
Are you sure the image is correct? Never heard of only the menu being reversed.
Oh and you need to get comfortable putting your hand inside the projector if you want to get it anywhere near it's potential.
http://www.etechvideo.com/techtip3.htm
_________________ SNR of people are ridiculously low.
dvh99
| Posted: Wed Apr 28, 2010 1:32 pm Post subject: |
turn around the connections coming from the hdm (between blue and green).
if its just the menu i dont know whats wrong.
have you compared video material on your monitor or tv.
dennis
Sparky015
| Posted: Wed Apr 28, 2010 1:41 pm Post subject: |
I think you need to open it up and check the orientations of the connections. Sounds like it's not fully set for ceiling or fully set for table mount. There should be diagram on the lead shield that tells you how to change the connections for the mount you are using (table or ceiling). If not, check out the manual on Curt's site. It shows you what to do. If that's not the issue, you may have a CLM issue, but not sure until you swap boards.
_________________ ~Paul
Sparky015
| Posted: Wed Apr 28, 2010 1:55 pm Post subject: |
There are 6 connectors that need to be oriented to properly set the pj for table or ceiling mount configuration. Don't worry if you are a newbie or not good with electronics. Just follow the diagram and unplug and replug. So easy, even a caveman can do it!
fosgate500
| Posted: Thu Apr 29, 2010 5:06 pm Post subject: thanks for the tips,help sirs,im gonna work inside |
thanks everybody for your help, tips and im gonna work all day, but the friday in the afternoon im gonna open the marquee ,before i gonna read again the manual for settings,and post my results
best regards
| Posted: Thu Apr 29, 2010 11:45 pm Post subject: |
Please remember to disconnect the power before doing this.
| Posted: Sun May 02, 2010 10:17 am Post subject: |
Another common quirk with the Marquee.
If you wish for it to be correct while viewing, you have to stand on your head and look at it through a mirror.
A small price to pay for being a member of the Marquirk forum
_________________ Chip
fosgate500
| Posted: Wed May 05, 2010 7:28 pm Post subject: i made the changes but right now light on tubes |
hi everybody, im made the changes for reversed scan, but was necesary remove the hdm module for change the h cables (m9000 july 94) then im insert the board again , close the case, and turn on, the marquee turns ok, but the tubes are dark, no light only the power suply sounds and the fans too,
im checked behide an the v fail red led in on,ive remove the hdm module and change the sockets again like before(inverted image) and the same, v fail turn on in red.
i m never touch the vertical board, only the horizontal,
im tried to conect a simple dvd player throught video rca, i dont know if the input module coulbe the problem. the vertical module the horizontal module,focus board etc,,,
a some clue for helpme
thanks
dvh99
| Posted: Wed May 05, 2010 7:52 pm Post subject: |
try reseating the hdm firmly with 2 hands then check the connections (pull out and put back).
are all 3 tubes connected on the vdm and hdm.
dennis
Sparky015
| Posted: Thu May 06, 2010 12:13 pm Post subject: |
check the connections you made to the vertical board. If you didn't put the connectors on correctly, it will give you a v fail error and not allow the HVPS to activate. Why did you need to pull the HDM?
David_Web
| Posted: Thu May 06, 2010 3:24 pm Post subject: |
Some HDM don't come with cables but have plugs directly on it.
It is possible one of the Vertical scan cables came slightly loose which would prevent startup and show the V-fail error.
