NEC XG135LC White Line
Michael Williams
Posted: Tue Apr 20, 2010 9:53 pm    Post subject: NEC XG135LC White Line
Hi Guys
I have just done a G2 alignment and color balance using a colorimeter. And installed a Moome HD card.
Now I have a white line at the top of my image. The line does not appear to be input related. It is just outside the extents of the projectable image area. It is a perfectly flat white line probably only the equivalent of 1to5 pixels in height.
- blanking does not get rid of the line as it is outside the image area.
- moving the raster does not have an effect but it DOES move the line up or down
- moving the image does not have an effect but DOES NOT move the line
- If I go back to HD Fury and VGA input, the line still remains
- The line is visible as inputs are changing.
I know it must just some setting I must have changed, but not sure
? Blue Focus ?
? Test Switch ?
My Setup is now a HTPC and PS3 with Moome FullHD XG card.
Thanks Heaps
Michael
jarseneau
Posted: Tue Apr 20, 2010 10:22 pm    Post subject:
That line is the AKB line. Typically it only ON when you adjust brightness and related items and goes away when exit the adjustment. It could be that you left the G2 setup TEST switch in the test position.
Jerry
Michael Williams
Posted: Wed Apr 21, 2010 1:17 am    Post subject:
Thanks Mate.
Thought this might be the case, and will try when I get home
At least now I will be able to concentrate in meetings this afternoon...!
Cheers
Posted: Wed Apr 21, 2010 10:26 am    Post subject:
You can turn it on and off in the Info menu (I think).
Assuming you haven't left the test switch in test.
Michael Williams
Posted: Fri Apr 23, 2010 5:07 am    Post subject:
Thanks Guys,
Problem Sorted.
Posted: Fri Apr 23, 2010 5:22 am    Post subject:
Well? What was it?
