Marquee 9500 convergence
DGP
Posted: Sun Apr 04, 2010 12:36 pm    Post subject: Marquee 9500 convergence
I can’t get this right. When I bought the projector, it already came with this problem. I tried everything I know to solve it without success ( Projector initialisation reset, magnetic alignment).
Using a 1080 crosshatch is easy to see that the last horizontal line of the red channel is always misaligned. If I correct this using the convergence adjustments, than the previous horizontal red line will be misalign.
The pictures are not great quality pictures, but show what I see on screen.
What can cause this?
Diego
 Filesize:  38.12 KB
 Viewed:  5181 Time(s)
 Filesize:  39.27 KB
Posted: Sun Apr 04, 2010 12:52 pm    Post subject:
DID you do a pretty close red and blue hight set up in the guided mechanical set up help menu? i found if you do not get the red and blue as close it could affect the proper convergence.
Also try messing around with S and C linearity and the size controls.
Then try Green convergence.
Posted: Sun Apr 04, 2010 3:09 pm    Post subject:
All convergence should be zeroed out ( 0 + exit & save), then the Raster heights matched in the Utility's menu to get all 3 grids the same size vertically. Also should be done horizontally with a special tool. Without this Convergence will be crap.
The reason I think it's off on so many machines is that a tube or tubes were replaced at some point and raster sizes were never corrected afterwords.
Posted: Sun Apr 04, 2010 5:09 pm    Post subject:
I agree Dragan, Also when tubes are replaced they might not seat the deflection coil up against the tube bell as far as it will go. That could also play a part.
Posted: Sun Apr 04, 2010 6:11 pm    Post subject:
yes certainly, whether or not the old hot-glue is removed, how much glue is around the boot (8 inch tube), etc. all plays a part. I also suspect every tube and coil combo will yield a slightly different size raster as well.
DGP
Posted: Sun Apr 04, 2010 6:22 pm    Post subject:
Thanks for the replies. I checked the vertical sizes in the service menu, but I never reset all convergences before adjusting the vertical sizes, as Dragan recommended. I will do that and see what happens.
I also consider that the deflection yoke was not at the right position, but at least with this projector, this is not the case.
Diego
Posted: Sun Apr 04, 2010 8:56 pm    Post subject:
Go into your service menu (0901) and press: 3
That will put you in the R/G vertical size menu to adjust the separate size of either Red or Blue to match, or get closer to green.
Sometimes you have to actually move the R/G size in the service menu to correct that convergence problem. Extend it first in one direction - try it - then go in the other direction.
DGP
Posted: Thu Apr 15, 2010 10:25 am    Post subject:
Finally I solved the problem.
I did a full setup (mechanical and electronics) and the problem is gone.
I think that the issue was related to the convergence, I mean I used too much convergence compensations. I followed the recommendations of Dragan and Mike but I was not able to completely solve the problem. I noticed that displaying a crosshatch I had the center of the crosshatch really not centered on the tubes faces with the all convergence null.
The projector has a set of Sony 1292 frankenyokes installed but I changed the original Sony magnetics by a set of Barco magnetics just because the magnetic strength of the Sony magnetic rings was not enough for the Marquee. When I had the magnetics rings separated and all the coils in my hands I decided to put them in the right order, I mean exactly the same order than the Thomson focus yokes (static closer to the neck / dynamic). Then I reassembled the magnetic rings but following the magnetic polarity of the Thomson yokes. So now I have a set of focus yokes with all the benefits of the Sony 1292 coils and the extra strength in the magnetic field of the Barco coil. The result is that the static and dynamic focus are really close (39/50) and the under focus is not an issue anymore.
It is well known that by using frankenyokes you loose the possibility to adjust the raster position. To solve this I did exactly the same that another forum member already explain here. https://www.curtpalme.com/forum_archived/viewtopic.php@t=2498.html
This is a great solution for raster centering. So I re-initialized the projector and started with the geometry, mechanical setup, then astig and focus. Once a had a perfect 16:9 1080p crosshatch on screen, using the 2 pole CPC installed between the convergence and focus yokes, I centered the raster on the tube face. To find the center on the tube faces I used an old lens that I did two marks on it using a soft pen. Booth marks should be perfectly centered. Once installed in the projector, I simply look thru the lens until I see the booth marks align and then move/rotate the special raster centering CPC to align the crosshatch with the booth marks. Really easy job Thumbs Up .
Please take a look to the attached picture.
Once I had the crosshatch centered in all tubes I readjusted the angle of the Red and Blue tubes to mach the green on screen. Then Red and Blue size, some minor optical adjustments, convergence and that's it.
Mods and upgrades I have in my 9500:
HD Dragan Mods
Frankenyokes (Sony 1292 coils but using Barco KF-3203 magnetics)
2 Pole CPC magnets between the convergence coils and the Focus yoke
MP Mikrons (waiting the Super VIM 02 version)
HFQ900 lenses
Red C-Element
Convergence Ground Strap
Thanks for your help.
Diego
 Filesize:  40.01 KB
 Viewed:  4957 Time(s)
Sparky015
Posted: Thu Apr 15, 2010 11:28 am    Post subject:
wow, you have HFQ900 lenses. I'm jealous! Razz
~Paul
Posted: Thu Apr 15, 2010 11:58 am    Post subject:
Hello, nice to hear that you liked that centering method Thumbs Up
DVDO VP-50
New hobby, Rally
Posted: Thu Apr 15, 2010 3:30 pm    Post subject:
Glad you did the magnet swap like we mentioned in out PM's and in the FrankenYoke thread. I do feel that that combination is the best focus system for the Marquee. It shows in your pics here:
Posted: Thu Apr 15, 2010 3:59 pm    Post subject:
those test patterns are impressive,getting a CRt to focus that tightly is more of an art-form than a skill
Posted: Thu Apr 15, 2010 4:11 pm    Post subject:
I agree drags!! I need to practice more on the edges. On my blend I sacrificed the outer edges to get the edges in the blend zone best.
Athnasios
DGP
Posted: Thu Apr 15, 2010 8:38 pm    Post subject:
Hi Dragan, this is the center of the screen only, anyway the corners are not at same level but ok too. It took me some days to achieve this level of sharpness. I used and HD camera with a 12 times zoom fully in and a 1920x1080 40" LCD to calibrate the focus and the 6 +2 pole CPC magnets. I have the LCD close to me so no matter how far is the screen, I can work sitting just behind the project and see what I'm doing on the LCD Mr. Green . This is the best way I found to clearly see what I'm doing.
What I think I always did wrong is that I always did the raster centering before adjusting the geometry, specially the C and S linearity. As soon as you touch the C and S linearity, the center of the raster will move. So I decided to change the order of the procedure and it works for me. Once the projector position is ok, I only worked to get a perfect 16:9 crosshatch at 1080 60p on screen and then the astig and focus and just before doing convergence I did the raster centering with the 2 pole CPC nothing else.
Diego
