Another interesting failure- comments from techs?
Posted: Thu Apr 01, 2010 4:55 pm    Post subject: Another interesting failure- comments from techs?
Was working on a common CRT chassis, known for bad capacitors. This set had an orignal 677 hours on it. Got the set for $100, incl a Runco DLP and 3 video processors, ceiling bracket and manuals (!).
I always make it mandatory to test all the caps on this chassis due to the high failure rate, and sure enough, I found a bunch open. As I fired through the various boards, I found that only one value of cap was bad. I had about 8 of them bad in the set. Wide open. Picofarads instead of mucrofarads. Caps beside them were fine, and bang on value.
Mac, Mike or anyone else, has anyone ever seen this? One cap, all the same type are bad in one set? Bad cap run maybe, about 18 years ago? Smile
Sparky015
Posted: Thu Apr 01, 2010 5:02 pm    Post subject:
Not sure I would call it a bad cap run. I would call it a consistant one! Laughing Unless that chassis is under warranty, I would say they did their job.
~Paul
Posted: Thu Apr 01, 2010 5:05 pm    Post subject:
Dont know. My meter doesn't have a mucrofarads selection........ HAHAHAHAHAHAHAHAHAHAHAHA
Change the selector on your meter, lol. Your on the wrong setting.
Whats the ERS reading on them? Or is that your open reading? Then how about value test?
If the set is one that is common to have a large volume of bad caps then they used cheap made ones new and this would not be uncommon.
I've had tv's built in the early 90's where most of the caps in the set were bad and it was common from that manufacturer.
I guess there were many manufacturers trying to save money back then and bought stuff from shady suppliers.
Posted: Thu Apr 01, 2010 5:07 pm    Post subject:
What brand are the caps?
Posted: Thu Apr 01, 2010 6:58 pm    Post subject:
I don't think I've ever seen a particular value cap fail only. I'm more familiar with the caps going in certain circuits being more common.
Reading this is a first for me.
Concerning caps, My 9500Lc Ultra is either a 2002 or 2004 build year. It had about 40,000 standby hours, meaning it was on continuously for 40K hours before i got it.
In checking the caps, I've only found a few of them to have a problem. And when I changed out those few, it made no difference with the overall operation of the projector in performance or anything else.
caps continue at times to be very mysterious to me as well..Sad
Posted: Thu Apr 01, 2010 10:21 pm    Post subject:
I agree Mike!
It was an older NEC PG. It was all one cap that was bad, same voltage, same value. All had leaked out the bottom, so they were easy to spot. As you said, even though about 5 on the board didn't read ANYTHING on the ESR meter, the set continued to work, and my intermittent no pix was a bad HV board. Posting another problem about this set in another thread...
Mac, dunno the brand, they were stock NEC caps.
Oh, I should add, the set had some syncing issues as well that replacing these caps did indeed fix, but yes, I'll bet I could have left 4 of the 6 caps without adverse effect.
Posted: Fri Apr 02, 2010 5:14 am    Post subject:
yes you could have but what would that have done to the power supply in the long run? Isn't one of the primary duty's of Capacitors to take the load off the power supply and thereby provide stable power to the circuits?
The set might still run, but something somewhere else is working harder than the designers intended.
JustGreg
Posted: Fri Apr 02, 2010 7:08 am    Post subject:
Just when I think I'm getting the hang of the abuse of the alphabet youze techies use you throw new ones at me...
mucrofarads and ERS's..I Googled but came up empty. Wink
Serious questions now for the techies...
I built the Anatek Blue /Low Ohms ESR tester a while back from a kit (http://www.anatekcorp.com/esr_compare.htm) and put it aside without using it. I want to dig into the boards on my 8500; specifically the Astig Amp and Vertical board, and don't fully understand what the results mean.
I've read alot of their forum and tech materials and 'think' I have a handle on how to use it but I wanted to ask you all a couple questions on how YOU test caps:
1) How to determine the cap is 'open'
2) What the test result number means, eg, how would I know if the ESR is too high or low if I don't know what it SHOULD be?
Apologies for the segue/hijack attack. Embarassed
Greg
Posted: Fri Apr 02, 2010 7:16 am    Post subject:
This might help
http://octopus.freeyellow.com/esr.html
JustGreg
Posted: Fri Apr 02, 2010 8:10 am    Post subject:
Tom.W wrote:
This might help
Wow...that was quick. Laughing You're up late Tom (early?).
I was editing my post when you posted. Excellent link. Thanks man.
Got me some (more) reading to do. This will come in handy at work where I can extend my value to the company and possibly repair some of their frequency drives instead of them tossing them out.
To expand on my shameful hijack....the Anatek site has ALOT of useful newbie electronics info in the FAQ's section. Lots of tips and tricks from pro's that our pro's here will find amateurish,but good stuff for folk like me.
For example...I didn't know that when you replace a leaking cap you should wash the salts off a large area surrounding the problem spot. Or that a UV light helps identify if the corrosive salt has migrated or damaged traces. Pretty cool stuff.
Or to check for a bad solder joint you use a toothbrush or non conductive (duh) brush to push component leads around until the circuit reacts.
And there's some seemingly good tips on how to burn off G2/heater contamination without blowing up the tube. (Poor mans restorer). Dangerous stuff but worth trying on a shorted tube with nothing to lose.
This stuff is ADDICTIVE!!! Twisted Evil
Greg
Posted: Fri Apr 02, 2010 2:30 pm    Post subject:
Here's a nice little chart for you Greg, if you dont already have one. Read the notes above and below the chart also.
http://www.your-book.co.uk/design/esrchart.htm
Posted: Fri Apr 02, 2010 6:20 pm    Post subject:
The main problem with caps was solved some time back when they started using a different method (Hermetically) to seal them. Before then, it was common to see caps spew their innards. That's not been the case for awhile now that the caps are so well sealed from leaking and finding one that actually dried out on the shelf (shelf life) is also rare.
I don't really get into the ESR thing, I'm thinking it may have more to do with audio and passive power supplies, because most of these projectors are not bothered at all when a cap also shows a bad ESR reading.
I spent almost a month back in January and a part of February looking into the Marquee LVPS. We even showed scoped measurements showing what the signal looked like coming out of the supply. I used my LVPS which had 40,000 hours on it, and my test Marquees LVPS which had even more hours of use.
Because of the design of the LVPS, the only thing we really noticed to be a problem was that two of the series rail inductors could have been heavier in windings for more current. And the board design where they placed the switch transistor from the switching coil could have been a better design, but overall, it's really a well designed supply. And that explains why they rarely fail. And other than the 85 volt rail caps leaking from the switching voltage, and in some rare cases one of the CT caps will fail. But other than that, whatever is going on with the caps in that supply, it somehow does not effect the operation of the supply, even if they're leaking of suffering from an ESR issue.
Posted: Fri Apr 02, 2010 11:15 pm    Post subject:
LOL. Good thing you didn't post this on a electronics repair site, Mike. The techs would hammer you silly.
Posted: Fri Apr 02, 2010 11:40 pm    Post subject:
Really... other than that NEC that Curt is working on, would they know of a Sony, NEC, Electrohome or Barco CRT projector that had caps exploding or leaking out crap that were manufactured in the later 1990's or anywhere in the 2000 years?
The later caps had the split in the top - why?
Posted: Fri Apr 02, 2010 11:46 pm    Post subject:
Mike, I think he's talking about you not getting into ESR. Frankly, I didn't either for the LONGEST time, but that ESR meter on eBay for $200 or so is the best investment I've made in a long time.
I run through boards now quickffast, and I find the strangest problems solved by caps with a high ESR.
Buy one, try it, and I guarantee that you'll find it damn handy.
Posted: Sat Apr 03, 2010 2:26 am    Post subject:
My comment was directed at caps, not projectors. Just like your comment was directed at caps and not projectors.
Your statement was that caps use to be made poorly and now they are not. Fact is, 20-30 years ago there were good made caps and poor made caps. Today..... there are good made caps and poor made caps. Its all up to the electronics manufacturer as to what caps goes in what.
Today, manufacturers need to sell tv's cheaply so people will buy them. So they use cheap made parts. Cap failure on standard consumer electronics built over the past 8 years is staggering. And that is a fact. I talk to these guys replacing them on a daily basis. And this includes tv's made through 2009. And other electronics devices are included in this also.
Now it appears that the higher grade and commercial grade electronics are using better quality components. Which is also why they cost more.
This was also the same in the 90's. I've worked on all brands of tv's built during this time and the same goes here. Some manufacturers used poor made caps and they would have consistent and multiple failures. Then there were some manufacturers that used better quality caps and they almost never needed to be replaced. Which is also why these tv's would run for 10, 15 even 20 years and never have a problem.
Todays good quality cap manufacturers have made great advancements in their products but there are also those shady manufacturers making crap caps. And the crap caps are going in the devices at the electronics manufacturers. Then the repair guy has to replace them with high quality one.
Now you would think that crt projector manufacturers would have used high quality parts in the devices, especially since they cost soooooooo much when new. But, who knows. For the most part they still seem to be holding up pretty well in what most here are running.
So the moral of the story is, there was good and bad..... and there still is good and bad. Money controls where they end up.
I will comment on your ESR comment in my next post so this one doesn't seem to run on.
Posted: Sat Apr 03, 2010 2:53 am    Post subject:
So still confused on ESR. I guess its my fault for not finishing the cap thread, lol.
ESR or equivalent series resistance is not a test of how a cap will perform in a circuit. It is not a test of quality of a cap. It is a test of the condition of a cap.
ESR is frequency dependent. What that means is that ESR will be different at different frequencies. Now since there is fluid in a cap you cant test it with a basic ohm meter. Even this fluid has some resistance when passing a frequency. The less fluid there is the more effective resistance the cap will have. Other parts of the cap also have effective resistance but fluid loss will have the most effect over time as the cap wear out.
It had been found that the most efficient way to test ESR is to pass a 100khz signal through the cap and measure it on exit. This will then calculate how much resistance the cap has and when compared to what a known good cap should be you can determine if it is starting to fail.
Now, how will this affect the circuit its running in? Depending on how much ESR it has it may not affect it at all. Why? Remember I said that ESR is frequency dependent. Well if a cap is showing 10 ohms esr, meaning its is going bad, it may not show any resistance in the circuit its in because that circuit may be running at a frequency other then 100khz. So the circuits frequency may show a normal ESR at its frequency.
And your scope patterns would all be normal................................
So what does this mean?
It means that even though the cap is preforming well in the circuit that it is in...... it is still failing. Because the ESR test has shown the cap has lost some fluid and is starting to fail. How long before it fails? That depends.
If you remember the cap thread there are circumstances that will cause the core of the cap to over heat. And if the core is overheating it will cause the cap to fail even faster. And as more fluid is lost from this over heating the hotter the core gets until there is no fluid left and now the cap also fails a value test and the circuit is surely affected, possibly damaging other expensive parts.
So even is the cap is still performing in the circuit its in, based on a scope test or other, but the ESR test shows the cap is failing...... it needs to be changed. Because its failure rate is now increasing very, very quickly.
So your scope may show the cap is performing perfectly but 100 hrs from now it fails and takes out multiple other expensive parts along with it. ESR test is very important.
I think I covered it but if I missed something.... ask away...... Smile
Posted: Sat Apr 03, 2010 8:16 am    Post subject:
Mac,
I appreciate your vast knowledge on caps and your experience on consumer electronics, which too have also been involved in.
But my comments is more geared toward commercial grade product, which does not and have not been using the same grade caps. therefore our experiences have been slightly different. So can you answer my question on which CRT projectors manufactured in the later 90's on had caps that leaked the same way that Curt indicated on that particular NEC, and why was the split later put on the top of the cap?
Or do you have any experience with the later commercial grade equipment and the caps used?
Concerning ESR. It would be nice to have a ESR meter and I plan to get one one day. But you'll be surprised at what one could do simply with a scope and the right equipment.
And my comments on the LVPS and ESR... If a marquee LVPS has been working flawlessly for thousands and thousands of hours, at what point did the high ESR cap caused it to fail. Forget the consumer stuff for now. no way would it ever get those hours of use on it and still maintain good scoped readouts.
No question I understand ESR. so don't think you need to finish a thread on caps to make sure I'm informed properly on it. And also keep in mind what I said about certain caps failing in certain circuits, which I find to be common because of the circuit. But regardless of the theories, what caps of the later batch used in commercial gear has had a high failure rate from drying out. leaking out on the board from the bottom. And other than the CT cap failures, which commercial grade CRT projector using the later caps has a history of ESR failing caps in the power supply that actually caused the supply to fail?
Posted: Sat Apr 03, 2010 9:04 am    Post subject:
Ok, so you are also acknowledging here that there are better made caps, as well, as there still being cheaply made caps.
Do you think these cheaply made caps would hold up in the switching power supply, deflection, etc. of one of the projectors I've mentioned?
Are you agreeing with me here??
Of course this would be the case. where were these TV's manufactured and what would be the production cost of each one of them. Even on the ones also being used in commercial applications to get around the cost of the more experience commercial monitors, when I'm asked about repairing one, I simply suggest replacing it. Giving the quality of the components I've been seeing in them, I'm surprised they work as long as they do.
It means that even though the cap is performing well in the circuit that it is in...... it is still failing. Because the ESR test has shown the cap has lost some fluid and is starting to fail. How long before it fails? That depends.
Again, I fully understand ESR and the importance of it. My point is simple, if I've been seeing projectors run up to 100,000 hours and did so without a cap failure. Would these projectors be using "cheap" caps, or is it possibly that the cap is a better grade cap that may also be an inexpensive cap?
JustGreg
Posted: Sat Apr 03, 2010 9:37 am    Post subject:
So, to re-cap........ Mr. Green kidding.
Very very informative for electronics toddlers such as myself. I followed some of the links at anatek.com and there's a Chinese (??) gentleman who used an analog VOM for years and years combined with a freq generator to test caps. He just recently started using the Blue ESR Anatek designed by Bob Parker. (What's with those Parker boys and what did they eat as kids to get so damn smart). Laughing He's also peddling a line of e-books that boast anyone can fix almost any consumer electronics with a few 'simple' pieces of diagnostic test gear. uh huh.
Thanks for the chart Mac...soooooo much easier to digest than the simple graph stick(er) on chart anatek provided for the meter I built. It actually makes sense now that I see the one you pointed me to but 'yours' (Bob Parker circa 1998) is more detailed.
Greg
