g90 input A not working
Sunstone
Posted: Sun Mar 28, 2010 10:11 pm    Post subject: g90 input A not working
it says input a is not applicable . useing johnhwman v1 input card for input b and an add on rgb for input c . input b and c work fine
HaydnG90
Posted: Mon Mar 29, 2010 3:48 am    Post subject:
Check the service menu and make sure 5BNC is set to OFF. That should fix your problem.
Sunstone
Posted: Mon Mar 29, 2010 11:18 pm    Post subject:
thank you Smile
HaydnG90
Posted: Tue Mar 30, 2010 3:33 pm    Post subject:
You're welcome. Make sure you replace that old DALLAS chip if you haven't already. If it starts to fail you'll have all kinds of headaches to deal with, not least the loss of calibration data.
Sunstone
Posted: Sat Apr 10, 2010 8:32 pm    Post subject:
is the dallas chip going to fail on all g90s? and how much for one and where to get it?
Posted: Sat Apr 10, 2010 8:46 pm    Post subject:
Hello
Yes all Dallas bram chips will eventually fail, they have a battery built in to provide memory with power unplugged. You will lose all settings when the chip is replaced.
