Sunstone
Joined: 11 Aug 2006 Posts: 44 Location: Rockledge Fl.
| Posted: Tue Mar 23, 2010 8:53 pm Post subject: g90 1080p? |
on the projector ratings list it says the g90 has 135mhz bandwith. then how does it do 1080p at 160mhz? i not saying it can or can't . just want to know from the experts
dturco
| Posted: Tue Mar 23, 2010 8:56 pm Post subject: |
Well 1080p only needs 67.43? by 59.94, Ok lets just 68x60. So no problems at all for a G-90.
http://www.hulu.com/firefly
| Posted: Wed Mar 24, 2010 10:23 am Post subject: |
Sunstone, dt is talking abut refresh rates.
| Posted: Wed Mar 24, 2010 12:34 pm Post subject: |
I just love posting this photo... G90 running 1080p @ 72Hz and doing it very well
dturco
| Posted: Wed Mar 24, 2010 7:53 pm Post subject: |
| CIR Engineering wrote: | I just love posting this photo... G90 running 1080p @ 72Hz and doing it very well
craigr |
Bite Me
Sunstone
| Posted: Wed Mar 24, 2010 8:08 pm Post subject: |
i glad it can ,mine is in shipping now. hope it gets here in one piece
| Posted: Wed Mar 24, 2010 8:49 pm Post subject: Re: g90 1080p? |
| Sunstone wrote: | | on the projector ratings list it says the g90 has 135mhz bandwith. then how does it do 1080p at 160mhz? i not saying it can or can't . just want to know from the experts |
The 135mhz figure is not correct technically. It's just a good marketing figure, because no one ever put any of the Commercial projectors through real bandwidth testing, so things got out of control a bit and that's why the specs were so hyped on bandwidth ratings.
The 135mhz figure is higher than any other CRT projector out there at the time, but the actual bandwidth rating is not higher than a few of the other CRT projectors manufactured at the time.
The neck boards in a G90 is fairly high in bandwidth rating. They probably will do better than 135hz, but the input board in no way would handle 135MHZ.
Sunstone
| Posted: Thu Mar 25, 2010 2:40 am Post subject: |
with the bandwith mods you came up with ,will it do 135mhz? and are your mods finished ? how to get them?
| Posted: Thu Mar 25, 2010 2:49 am Post subject: |
| Sunstone wrote: | | with the bandwith mods you came up with ,will it do 135mhz? and are your mods finished ? how to get them? |
Absolutely. But most importantly for the G90, the mods will produce a much cleaner/tighter video chain. So regardless if you're running 720P, 1080P 60 or 72hz, the image would be better.
They're almost done. I thought I would have been finished with it last week. I'm now only tweaking the gamma mini board to work with the internal gamma menu.
| Posted: Thu Mar 25, 2010 10:17 pm Post subject: |
| mp20748 wrote: | | Sunstone wrote: | | with the bandwith mods you came up with ,will it do 135mhz? and are your mods finished ? how to get them? |
They're almost done. I thought I would have been finished with it last week. I'm now only tweaking the gamma mini board to work with the internal gamma menu. |
Congrats Mike! That is great to hear.
Looks like the G90's are gonna have to come off of the ceiling huh?
Sunstone
| Posted: Thu Mar 25, 2010 10:40 pm Post subject: |
my g90 just got in !! it has perfect tubes, not bad for 1325.00 and he gave me a used g70 , just to get rid of it.it has some tube ware but good for backup
| Posted: Fri Mar 26, 2010 1:56 am Post subject: |
| overclkr wrote: | | mp20748 wrote: | | Sunstone wrote: | | with the bandwith mods you came up with ,will it do 135mhz? and are your mods finished ? how to get them? |
Looks like the G90's are gonna have to come off of the ceiling huh?  |
I would definitely like to get a modified board in one of those G90's and see how it compares to the other with the stock board in it.
Yep... the bandwidth improvement and cleaner image combined with a very special High Performance GAMMA circuit.
The end results -- Improved sharpness, detail, colors, clarity and depth of field. Imagine that being stacked into a more intense image..
