RickNa
| Posted: Thu Mar 04, 2010 1:32 am Post subject: Sony G90 Input Setup for IFB-FULLHD Card |
I had this set up once by a firm that does this but now I cannot get the Sony to recognize the IFB-FULLHD input. I looked quite alot to see if there is a topic on this but could not find one. It may be too much to ask but is there a step by step method to get Input B on the Sony setup correctly? I know enough to only be dangerous but I don't know all the settings that are needed to get the Sony to see the Panasonic DMP-BD30 Blu-ray player. The Blu-ray is hooked directly to the IFB-FULLHD card.
Note, and I don't know if this is an issue, I have both the component and the HDMI going from the BLu-Ray to the projector. The component goes through my Faroujda 5000 processor first. I do this so I can see the BluRay menus to change it over to 1080p/24.
Thanks and if this has not been answered here, does anyone know where I can look? I don't want to call the service guy out again and spend the money if I can figure it out myself.
Equipment of interest to this:
Sony G90
IFB-FULLHD
Rick
betel
Joined: 20 Apr 2006 Posts: 448 Location: Maryville, Tennessee (Just South of Knoxville)
| Posted: Thu Mar 04, 2010 2:04 am Post subject: |
CRT can't do 24hz.
| Posted: Thu Mar 04, 2010 2:07 am Post subject: |
Yep turn off 24fps and see if you can get 1080p/ 60 out to the Moome card
RickNa
| Posted: Thu Mar 04, 2010 2:38 am Post subject: Sony G90 Input Setup for IFB-FULLHD Card |
Still no joy, the back lights on the card keep flickering through DET(ect) and the Red on the left side (pj is mounted on the ceiling so i guess it's upside down). As it does this the Sony reports Existing Input Mem to No Input back and forth, that's all I get. I hooked the player to a TV, set it to 1080p (which that tv doesn't support) and turned the 24b off but I'm still stuck.
Rick
RickNa
| Posted: Thu Mar 04, 2010 3:31 am Post subject: |
Hang on, I may have a bad HDMI cable. I'll try to get another one and try it out. I'll let you know. Thanks for the responses.
Rick
RickNa
| Posted: Thu Mar 04, 2010 5:24 am Post subject: |
Well I tried a working cable and that's not the problem. I will intermittently get an error code on the Blu-ray that the manual describes as either:
-The connected equipment is not HDMI compatible
-The HDMI cable is damaged
When I connect the cable, the IFB-FULLHD's status lights oscillate between red and green in sync with the flicker of the Sony's status on the screen oscillating between no input and existing input memory.
I was able to set it to 1080p and turn off the 25fps but it still behaves the same.
Could the card have gone bad or is there something I can look at in the Sony setup. I do have the Clamp set to H/C.
Anyone have any ideas?
Rick
| Posted: Thu Mar 04, 2010 5:47 am Post subject: |
I just noticed you posted this in the HDFury forum. I'll move it over to Moome's forum. He'll jump in and help you.
moome
| Posted: Thu Mar 04, 2010 2:39 pm Post subject: |
| RickNa wrote: | Well I tried a working cable and that's not the problem. I will intermittently get an error code on the Blu-ray that the manual describes as either:
Rick |
the DET LED should keep light up and no blinking for normal case,
if it keep blinking every 2 seconds, it may a card problem.
you need send back for repair!
