Faroudja VP 400 output specs?
KiwiChris
Posted: Tue Feb 23, 2010 12:13 am    Post subject: Faroudja VP 400 output specs?
Hi all, newbie to the forum here, I'm hoping someone will be able to help me with my questions
I recently purchased a Faroudja VP 400 that had been removed from a super yacht for $10, apparently it is in good working order...
I would like to use this to upscale old VHS tapes
I have tried scanning the internet but haven't be able to find any manuals or other info on this unit. I think it is a '95 model. I have two questions;
1. I know it outputs a "quadrupled" RGB HV (2100 lines 64Khz I believe) but I dont know what that means in terms of the type of monitor that would accept that signal, would a modern 1080i HDTV that has a RGB 15 pin D-sub connector be able to display the output?
2. I am also interested in capturing the upscaled output and would appreciate any recommendations on a PC frame grabber / video capture device that could accept the output from the VP 400
thanks!
Posted: Tue Feb 23, 2010 12:17 am    Post subject:
You need something that will do 1024p, or about 64Khz. Most of the older monitors will only do up to 768p or so.
KiwiChris
Posted: Tue Feb 23, 2010 10:29 am    Post subject:
Thanks for the quick reply Curt, do you have any suggestions for a capture device?
cheers
Chris
